Part identification f4zb-15a567-ab
Old Jul 8, 2016 | 08:03 AM
kmac22068's Avatar
Hi,
Does anyone happen to know what relay this is for?
part number f4zb-15a567-ab
Thanks!!!!
Old Jul 8, 2016 | 08:30 AM
Joeywhat's Avatar
It's likely impossible to tell what the relay is for given only a part number. There are likely more than one of them used on your vehicle. The location/use of all relays and fuses is typically in the owner's manual, which can be found online if you no longer have it.
Old Jul 8, 2016 | 10:19 AM
kmac22068's Avatar
I have googled the number etc..no luck...
Old Jul 8, 2016 | 10:21 AM
Joeywhat's Avatar
I'm sure... Did you read my post? It's just a part number. There are thousands of those in existence, all with that number on it.
Check which socket you pulled it from, then check the fuse diagram to see what it controls.
Old Jul 8, 2016 | 10:59 AM
SpectreH's Avatar
A few sites hinted it might be related to the rear defroster, but I have found nothing definitive.
Old Jul 8, 2016 | 07:17 PM
houtex's Avatar
Trunk latch relay... if this listing is any indication:
http://www.ebay.com/itm/94-98-Mustan...-/331136046585
And you can see it in the pictures, so I bet it is.
However, it's a relay. Relays can be used for all sorts of things, not just latches and radio amps.
Hope that helps!
Old Jul 11, 2016 | 06:39 AM
kmac22068's Avatar
YUP!!! THANKS!!
I have complete;y restored a 97, but the trunk is still off as the new soft top is going on the 20th. I saw this piece on my parts shelf and was baffled..
Old Jul 11, 2016 | 08:43 PM
houtex's Avatar
95ripper
Jul 14, 2010 09:38 PM
jmgford
Dec 19, 2004 03:53 PM
buckfu
Nov 17, 2004 11:01 AM
kembond
Nov 5, 2004 06:28 PM
upstate
Oct 15, 2004 09:46 PM
