No bass with aftermarket deck
Old Apr 8, 2012 | 10:19 AM
gray_fox's Avatar
I believe I hooked the wires up right put still no bass with the Mach 1000 system.
Old Apr 8, 2012 | 10:26 AM
NYGMEN's Avatar
Did you get an extra set of RCA cables to plug into the head unit? That will carry the signal to your amps.
Old Apr 8, 2012 | 12:35 PM
gray_fox's Avatar
Yes it did and they are plugged up and still nothing
Old Apr 8, 2012 | 02:08 PM
gray_fox's Avatar
This is what I have. Do I need to hook up one blue/white wire or both?
Old Apr 8, 2012 | 02:58 PM
Dbranham's Avatar
The blue should be hooked up
Old Apr 8, 2012 | 03:00 PM
NYGMEN's Avatar
Been a while since i did mine, see if this helps
http://www.modularfords.com/content/...o-mach460-214/
Old Apr 16, 2012 | 11:23 AM
97GT03SVT's Avatar
Don't mean to hijack the thread but I just had the same thing happen, I have had my aftermarket head unit, HD radio receiver for years and suddenly my bass is completely dead the door mounted subs are dead.. I did just replace my battery could this be caused by a blown fuse? I have the stock mach460 system on my 97 gt
Old Apr 16, 2012 | 12:02 PM
Dbranham's Avatar
Only the subs don't play? This is a most likely a blown fuse. I believe it is a 15 or a 30 fuse. Make sure you put the proper one back
Old Apr 16, 2012 | 02:16 PM
97GT03SVT's Avatar
Checked the fuses and they are all good, any other suggestions? I'd hate to bring this to a radio place to get checked out
Old Apr 16, 2012 | 02:29 PM
Dbranham's Avatar
Check the fuse coming from the battery?
Old Apr 16, 2012 | 02:44 PM
97GT03SVT's Avatar
I checked the fuse box, is there another location for more fuses?
Old Apr 16, 2012 | 03:13 PM
Dbranham's Avatar
Yes just one fuse thou
Attached Thumbnails No bass with aftermarket deck-image-2543885384.jpg   No bass with aftermarket deck-image-3504229787.jpg
Old Apr 16, 2012 | 04:19 PM
97GT03SVT's Avatar
Thanks again I replaced it unfortunately I have the same problem
Old Apr 16, 2012 | 08:54 PM
Dbranham's Avatar
Have you checked the cords running from the back of the head unit and to the amp it's self?
Old May 14, 2012 | 06:08 PM
97GT03SVT's Avatar
I know that this is long overdue but I finally was able to figure out the problem with my sound system.
After checking all the cords and fuses I wound up swapping in the amps from my 03 Cobra and the problem was solved. I hope this helps others in the future because it was a pain in the neck to figure out. Wish me luck on my bid for some amps on ebay to put back into the Cobra!
Old May 14, 2012 | 06:28 PM
skunk21's Avatar
good luck
Old May 14, 2012 | 09:20 PM
97GT03SVT's Avatar
Originally Posted by skunk21
good luck
Last minute some guy outbid me by a frigging dollar! Oh well I just bought a newer set out of an 04 Mach 1 for $90...
May 3, 2026 05:42 AM
muscle car fever
Oct 29, 2015 06:53 AM
CoyotePremium13
Oct 7, 2015 07:17 PM
trackpack13gt
Oct 2, 2015 08:20 PM
Sep 24, 2015 08:15 PM
