Just finshed installing IRS
Old Nov 30, 2008 | 11:57 AM
1bad01gt's Avatar
I just finished installing a Cobra IRS into my GT. Also installed a set of Eibachs, Tokico D-specs, a new torque converter and valve body. It's a huge difference in handling. I also now shifts wonderfully crisp. I had to set the shift pressure back to stock to keep it from chirping on shifts just driving normally. Next in line is to do more mods in the engine bay. I installed a HPS intake, C&L upper plenum, 75mm TB and a CAI with a tune a couple of years ago. I'm going to install 24lb injectors, and a 85mm MAF, along with a set of MSD coils over Christmas week. I think just maybe, I'll be done...at least for now.
Attached Thumbnails Just finshed installing IRS-mussie-1.jpg   Just finshed installing IRS-mussie-2.jpg
Old Nov 30, 2008 | 12:37 PM
cntchds's Avatar
How much better does it handle with the IRS in? Can you feel the weight in the rear in comparison to the SLA? I'd love to do the swap myself, but nobody wants the short 94-98 axles in their Cobra, and I can't afford the 900-1200 bucks to buy one.
Old Nov 30, 2008 | 01:21 PM
1bad01gt's Avatar
It handles much better than before, but I also changed the struts, shocks and springs. The biggest change is the ride on bad roads. No more rear hopping over bumps. The car seems more balanced with the extra weight in the rear, with no performance loss. In the end, the view was worth the climb...
Old Nov 30, 2008 | 01:41 PM
future9er24's Avatar
Sweet lookin GT man
Glad to hear more "its worth it" talk about IRS. I'm hoping to get it in mine soon
Old Dec 12, 2008 | 04:15 PM
edumspeed's Avatar
Legacy TMS Member Pr
Neat car you got there man!
Old Dec 17, 2008 | 04:47 AM
Evil_Capri's Avatar
NICE!
Old Dec 17, 2008 | 06:43 AM
Redbaron93's Avatar
Very nice looking car. Love the color. I right there with you on the '93 LX 'vert project.
Old Dec 17, 2008 | 04:51 PM
conv_stang's Avatar
Looks great man! stance is killer
Old Dec 20, 2008 | 08:14 PM
AFChief's Avatar
Car looks GREAT!
Where can I find a "how to" or write up on fitting IRS to a GT?
Old Dec 20, 2008 | 11:14 PM
Originally Posted by AFChief
Car looks GREAT!
http://www.angelfire.com/bug/irs0/index.html
Old Dec 20, 2008 | 11:29 PM
EagleStroker's Avatar
I don't do trannies
or rear-ends anymore!
I've heard that a watts link does the same thing, but I'm not sure do they offer them for your year car?
Just a thought, I'm staying open minded on this one because I'm inexperienced with it
Old Dec 21, 2008 | 05:30 AM
karman's Avatar
The Watts link helps with those problems, but it isn't the same at all.
There are a few different Watts links available from different makers for that year.
Old Dec 21, 2008 | 07:11 PM
lowblustang00's Avatar
If you don't mind me asking how much did the swap run you? What all was required for the swap and where did you find the parts at? I have thought about this for a long time and never persued it, but you have re-inspired me.
Old Dec 22, 2008 | 07:41 AM
1bad01gt's Avatar
After selling the solid axle rear and the cat back, it cost around $1,450, minus the transmission stuff. The IRS came with just about everything but the brake hoses. After I installed it, I was able to do a couple of slight bends to the hoses to not have to replace them. I got a pretty good deal on the IRS, though. I paid $1,200 for the IRS, $600 for the Tokicos and $500 for the cat back. I sold the old rear for $450, the old cat back for $200 and the cobra rear discs for $200. I already had 11.65" rotors on my car.
The swap was simple. I dropped the old rear and control arms out and removed the quad shocks and brackets. I installed new brackets where the quad shocks bolt up to the frame rail. The IRS took about 15 minutes to bolt up and maybe another hour to hook everything else up. The cage bolts to the lower control arm mounts and to the brackets that get installed where the quad shocks were. I never even had to unbolt the calipers, so I didn't need to bleed the brakes. If you do this, make sure that the IRS comes with the rear brackets and antilock sensors. The sensors are different, but run the same place in the frame rail and plug in under the rear seat. Also, you'll need to change the rear yolk on the driveshaft. The IRS yolk is much larger than the GT's. Because my car is an auto, I needed to have my driveshaft cut 1". I've had the car up to about 90 with ni vibrations at all.
Old Dec 22, 2008 | 10:00 AM
AFChief's Avatar
Did you get the IRS locally?
Old Dec 23, 2008 | 05:14 AM
1bad01gt's Avatar
No. I had it shipped to me. The $1,200 included the freight cost. I found it on eBay after looking for one for several months. It came out of an 04 with less than 10K miles on it. It looked almost brand new. I passed over many others because of cost or condition. I also wanted one with the 31 spline axles. It's not a cheap upgrade, but I'd do it again.
Old Dec 23, 2008 | 02:46 PM
USMC0341's Avatar
Looks great!
Feb 10, 2017 07:12 PM
Sep 16, 2015 06:44 PM
Sep 10, 2015 12:44 PM
Sep 8, 2015 10:45 AM
SMOKE46
Sep 6, 2015 09:40 PM
