Intake Manifold
Old Jul 11, 2011 | 06:40 PM
Quicksilver-4.6's Avatar
My 03 GT has the dreaded coolant leak from the p.o.s plastic crossover. I'm looking at a couple different new intakes. I have seen them from 169.99 for the ford racing performance one from American Muscle ( http://www.americanmuscle.com/intake...FQ8r7AodECRhWg )
The question I have is, the 500-600 dollar pro series from American muscle , is it worth that much more to get a all alum one vs a composite plastic one? Are there any hp gains that would be worth spending that much more, and or any performance gain what so ever? I'm not looking for any gains , but if it helps the motor breathe better or perform any smoother I would take it into consideration. But an extra 400 bucks is a lot for justba intake manifold right?
If any one has installed one on their stang, is it something I could accomplish in my garage myself instead of having someone do it for me?
I'm not a ford mechanic but I do know my way around a MY car.
Thanks for any help you can give guys :-)
EDIT: oh and it says it for the 4.6 with pi heads, anyone know what year they started using these in the gt's ?
Old Jul 11, 2011 | 07:27 PM
98gtdriver's Avatar
Pi heads are just power improvement heads hence the hp gain from the 98 to 99-04 mustang gt. They upgrade the intake manifold the heads and cams giving it 40 more hp and that's why they call it a power improvement intake mani.- just upgrade parts from the 98 gt
Old Jul 11, 2011 | 10:15 PM
asmodeus's Avatar
That's a lot of money for only 40hp. Granted 40 is a good gain. But hell ur looking at about 1000 bucks for 40 hp :/
Old Jul 11, 2011 | 10:34 PM
try a bottle of stop leak first, that's what I did to mine, and no more leaking.
Old Jul 12, 2011 | 06:29 AM
I guess since I have the 03 gt I have the pi heads already right? I'm only looking at spending the 169 for the intake manifold. I already have someone to put it on for me for free if I can't handle the job itself. I just didnt know if it was worth getting then pro series intake mani vs the composite plastic one. If I already have the pi heads I'm not going to see much if any gain if I was to by the over priced all alum one then right?
I would try the stop leak, but it looks like the shady *** person I bought the car from already tried to use silly puddy, or bond or some kind of adhesive like caulk. It's starting to dry up and crack away from the plastic crossover, it smells really strong of coolant if I get into the higher rpm range. So I'm guessing when I get in it it's spewing out from the crossover causing me to spend 1,000,000,000 rubles a week on coolants ;-)
Old Jul 12, 2011 | 11:19 AM
Planeswalker's Avatar
Yes, the 2003 already has the PI heads/intake. The only way you would see gains to justify the price is if you also get Cams, Headers, or Supercharger. If you don't plan on getting any of that then get the composite one, it will hold less heat than the metal one.
Old Jul 12, 2011 | 11:55 AM
Thank you sir. I plan on doing a 03/04 cobra motor and tranny swap, but that's a project that's still in the "design" phase. Plus I can't get the bank ( my wife ) to see my point of view of why in the world I would need to spend that much money on a car that has only 72k . :-)
Old Jul 12, 2011 | 12:01 PM
Ditto. Stuff works great. Used it many times over the years.
Old Jul 12, 2011 | 12:08 PM
Would that be like putting a band-aid on a machete wound? Good until you can fix it? Or would that fix it in defiantly ?
I can hear it releasing pressure from the crossover once it's warmed up and I cut the car off, and its using about a gal of coolant every week and a half or so. If it doesn't maintain a certain pressure in the cooling system will this have any effect on other mechanical issues down the road?
Old Jul 12, 2011 | 10:02 PM
stop leak fixes it from the inside out, you put it in your radiator, and it runs through. how it works, I'm not sure, but I'm pretty sure it's magic.
Old Jul 13, 2011 | 09:22 AM
Ha ha ha brilliant!
Old Jul 16, 2011 | 10:14 PM
asmodeus's Avatar
Love this post.
Antigini-GT/CS
Oct 5, 2015 09:43 AM
RoushRS3
Sep 29, 2015 08:03 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
