How to remove center console?
Old Dec 29, 2009 | 10:24 AM
lowblustang00's Avatar
I appreciate any help. I don't have my Haynes manual with me, and want to install some dynamat under the center console when I put in my new MGW short throw shifter.
Thanks for the help folks.
Old Dec 29, 2009 | 03:20 PM
Tiberius1701's Avatar
This is the procedure from a 2004 Mustang-shouldn't be much different. Hope this helps!
File Type: pdf
Old Dec 29, 2009 | 04:53 PM
data174's Avatar
Go to search mode and look for a file called Installing a nav radio in a 2005 mustang. It will walk you through the removal and installation, with pictures.
Old Dec 29, 2009 | 07:52 PM
Thanks a lot Tiberius. I really appreciate it.
Old Dec 29, 2009 | 10:54 PM
cntchds's Avatar
Incase you haven't done it yet;
1. Remove shift ****
2. Pull out shifter bezel
there are two screws in the front that hold the console to the dash, I think they are 8 mm
3. Pull out the inside of the center console storage part. Just yank.
4. There are two screws under there, remove these, and all the fasteners are out.
5. Pick up the console from the back and pull backward until you can disconnect the harness plugged in underneath.
From this point you will be able to yank it out.
Old Dec 29, 2009 | 10:56 PM
cntchds's Avatar
This part of the board is for 94-04 Mustangs. That would not help here.
Old Jan 30, 2010 | 06:37 PM
HizliBullet's Avatar
anybody got pictured illustrations of it for 05-09?
Old Jan 30, 2010 | 08:32 PM
cntchds's Avatar
Ask the 05-09 forum. This section is for 94-04 Mustangs.
hpb50
Sep 27, 2023 03:03 PM
Diode Dynamics
Jun 12, 2018 03:26 PM
Diode Dynamics
Feb 28, 2018 09:37 AM
