Help needed making up my mind
Old Feb 25, 2013 | 01:07 PM
outlawmack's Avatar
Ok here's the deal. I have a 95 gt 5 speed that I want to make a real healthy street car 425475 rwhp. Something that I can drive everyday and run high 11's low 12's not overly done where you have to buy race gas and not practical.
Option 1. 306 with a turbo or supercharger
Option 2 Stroker motor with the factory 302
Option 3 351w swap (but I know that would leave me to wanting more than what is needed)
I don't want to spend 10-15 grand on the motor. That would be a great down payment on a '14 gt
What are your thoughts and the setups that your using with hp numbers and times if you have them?
Old Feb 25, 2013 | 01:23 PM
TheMuffinMan's Avatar
Money would be better spent on a newer GT if you want the car for ever day use. I'm sure you can make it to the low 12's with the new GT's fairly easier without having to swap any motors and such plus they will have a nicer ride as well. Stock they run in the 12's. that being said your already starting out in the time you want it's all about lowering as much as you want. With FI the new GT can run in the 11's.
Old Feb 25, 2013 | 01:31 PM
read his post, he doesn't want to spend that kind of money.
I'd probably go with the turbo setup, you'll still get reasonable gas mileage, and you can turn up the wick when you go to the track.
Old Feb 25, 2013 | 01:34 PM
outlawmack's Avatar
Yeah but that's 40 grand I don't want to spend right now. Im trying to avoid payments. Wife and I are buying a house and moving south in June It would be a couple years on a new car. Plus we got to get her out of her cavalier first
Maybe I should just try mid 12s
Old Feb 25, 2013 | 01:39 PM
outlawmack's Avatar
I was looking at this kit. http://peregrineperformance.com/94-95%20Mustang.htm
Any other suggestions on a manufacturer. I read on the forum to stay away from on3 The guy had nothing but problems with them
Old Feb 25, 2013 | 01:51 PM
He said he didn't want to spend money on the motor than said it would be a good down payment on a 2014 so I'm lost what you meant by that. But turbo is good.
Old Feb 25, 2013 | 02:58 PM
he meant that if he was going to spend that kind of money, he'd just get a new car, but since he's not, he doesn't want to spend that much i.e. not spending a fortune on a motor setup
Old Feb 25, 2013 | 03:20 PM
outlawmack's Avatar
Right.. I know I'm going to spend 10-15 grand but I want that to include everything. Engine, trans, rear, suspension and brakes If its going to be in the 25-30 range, I'd just buy a new car
What I wanna do is run with, or better yet. Out run a new (semi stock) mustang for a third of the cost
Old Feb 25, 2013 | 03:28 PM
1999Pony's Avatar
You can run 12s with a good H/C/I combo on a 302. That's what I would do. For about 5k or so, you could have a very good street setup. Add in a good working suspension and tires will get you easily into the 12s. No need to go turbo route unless you really want to.
Going 306 doesn't give you much in the hp department, just overbores the cylinders. 12s are possible on a stock bottom end and what's listed above.
Old Feb 25, 2013 | 04:04 PM
outlawmack's Avatar
Yeah I know. The reason I said 306 is because my engine has 161k on it. It's going to need freshened up eventually
Old Feb 25, 2013 | 04:24 PM
1999Pony's Avatar
Well I cant say I blame you there. Might as well do it right the first time
Old Feb 26, 2013 | 11:31 AM
THIS99GT's Avatar
Get a turbo and supercharger
Old Feb 26, 2013 | 11:39 AM
outlawmack's Avatar
And stick it on a 427 stroker with a 150 shot of nos? That'd be fun for 6 seconds
Old Feb 26, 2013 | 11:41 AM
1999Pony's Avatar
Can you say yeehaw......
Jim74656
May 1, 2023 02:15 AM
Ecostang
Nov 3, 2022 08:50 PM
bigaaron
1994-2004 V-8
Aug 22, 2015 12:06 PM
nismos13s14
1994-2004 V-8
Jul 31, 2015 12:55 PM
