help??
Old Aug 26, 2011 | 11:56 PM
TAYLOR's Avatar
help??
so...i was replacing my heater core and u have to let down the steering wheel right? well i finished the job...slapped the sucker back into place like before (ive done this a couple times before btw) and everything was dandy. then i went to leave the next day and my key gets stuck in the ignition. really? i wiggled the wheel and stuff but it said no lol it will not turn back into accessory and it wont come out. but it does start the car and such just fine. what do i need to do?
Old Aug 27, 2011 | 10:35 PM
Planeswalker's Avatar
Wiggle the steering wheel back and forth while trying to remove the key.
Jack the front of the car up so wheels are just off the ground, try wiggling again.
Spray some Teflon dry lube into the ignition/key. Try wiggling again.
Put crushed ice in a plastic bag, set it on the head of the key only! The cold may "shrink" the key. Try wiggling again.
If none of this works you may have to call in a pro, the mechanism may be damaged.
Old Aug 27, 2011 | 10:42 PM
TAYLOR's Avatar
thanks. ill try some of this.
