Engine Swap...
Old Sep 14, 2005 | 03:18 PM
DrunkenDragon713's Avatar
they are both 4.6li. engines, but are they the same size? and has anyone tried or heard of this done before?
Old Sep 14, 2005 | 05:28 PM
future9er24's Avatar
it should fit just fine, as long as you have the computer and all the wiring and stuff that ya need.
i think....
Old Sep 14, 2005 | 11:42 PM
Mestizo's Avatar
i think....
The shell is the same so it will fit fine, but watch which year Cobra goes in there...because the 03/04 Cobras have a 6 speed transmission.
Scothew or SVOPaul would know more on this, but my guess is this:
Engine
Tranny
Speedometer needs to be calibrated or changed(different redline)
Crank...I believe the Cobras are forged metal they use a different bolt pattern
I'm not clear, but independent rear suspenion...."MIGHT" be needed
Maybe a new driveshaft....once again SVOPaul or Scothew are better in this area than I am
I've thought about a Cobra clone....etc, but some times that price tag is more expensive than a Cobra itself. I created a topic on this once...it might be of some help.....I'll post it later today.
If you're looking on the Ford Racing site....a MACh1(aka Mercury Marauder engine) engine might be a better alternative.
Old Sep 14, 2005 | 11:56 PM
Mestizo's Avatar
Here's the topic......but I forgot something......BRAKES. Cobra brakes are bigger and better for a reason. Also do a search on engine swap in the v6 forum there's a few topics.
http://forums.bradbarnett.net/index....opic=14748&hl=
Old Sep 15, 2005 | 10:55 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Everything you would ever want to know about putting a 4.6L 4v into a 4.6L SOHC based GT is in this website.
http://cobrapoweredgt.com/
The swap can be done fairly easy. If your car is a 5-speed car, the stock t-45 will bolt right up with any 96-01 4v motor. Since your car is a 00, i'd defintely try to go with a 99/01 4v just to make it easier with the COP (Coil On Plug) setup that you already have.
A chip in the computer to compensate for higher redline and larger injectors that the 4v requires.
Other things will defintely be covered by that website. It was made by the first person to do the swap and it was a huge hit on stangnet.com when alot of people were doing this swap.
Old Sep 15, 2005 | 10:57 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Btw, you dont have to change the rear end to IRS or even get cobra brakes. THose are nice things to have, but your GT stuff will work just fine. I like the cobra brakes because well, they just stop better :P
If you are able to use your stock tranny, which I think you will, the driveshaft now will be fine.
Old Sep 15, 2005 | 10:59 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Well it looks like they are redoing the site. Check their forums links and you should be able to find alot of the info you need.
Some of their pages are down for construction.
Old Sep 15, 2005 | 12:46 PM
My GT is an auto, so I'd still have to change the tranny possibably...
I'd love to either do this myself (with help of course) or get this done...
Just the idea of having a 300+ engine in my car gives me this feeling of "OOOOOOOO That sounds nice! "
Old Sep 15, 2005 | 12:51 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Not true. Im not sure off the top of my head, but I know a auto tranny can mount to a 4v motor. Lots of bracket racers do it with mild n/a and blown 4v motors. I know a different flywheel and maybe a tranny bellhousing will have to be used. I'll try to dig up specifics and let you know.
Edit: I just thought about it, but if a mach1 4v can be used with an auto tranny it should be easy them. Especially if the motor you got came from an auto mach1. May want to check with a ford parts dept and see what they say. Maybe talk to 05stangkc on this board as he helps our members out and is a great guy.
Old Sep 17, 2005 | 02:04 PM
Thanks for the help Scott.
I'm not planning on doing this for quite some time... since I'm still waiting on insurance to give me my check for my truck, which is still in St. Bernard in about 2 feet of water/oil. I'll get around 18k for it, this will go to pay back my loan and buy my wife a new car, which is also over there... at least I have my Pony huh?
I'm hoping once I get a good job and find a lonr term residence I can go all the work I have to do on my baby...
Old Sep 17, 2005 | 09:28 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Good luck to you Pat. Let us know if we can be of any help. If you happen to find your way up towards central AL, I can defintely recommend a few shops to help you out with anything you need stang wise
Old Sep 18, 2005 | 09:46 AM
Mestizo's Avatar
Well since you are in Dallas......you should probably check out Dallas Mustang...the same one in the mag.
They might be able to give an estimate. Then hide the estimate from the wife , as you save up for the swap.
Old Sep 19, 2005 | 12:40 AM
Mestizo's Avatar
Also I believe that the 1999 Cobra engines from Ford Racing, comes with the transmission. So it would almost be a pick-em(Mach/Cobra), which engine would you rather deal with, and if you prefer auto/standard.
I guess another question is.....the Cobra engine should be aluminum, but not sure on the MACh1.
Old Sep 19, 2005 | 01:16 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Both blocks are aluminum.
Road_Runner
Sep 2, 2024 04:46 PM
trackpack13gt
Oct 2, 2015 08:20 PM
Evil_Capri
Sep 11, 2015 08:39 AM
