Door unlocking help
You will have to remove the door panel and check the mechanisms which is kinduva pain. I had a similar issue on my Lincoln - needed WD-40 & some lithium grease. It's also possible something fell off or disconnected, but you will need to remove the door panel.
Antigini-GT/CS
10/5/15 09:43 AM
