darn belts squeak when moist.
Old Mar 13, 2007 | 01:05 PM
Knight's Avatar
Needs to be more Astony
Whenever it rains or there is dew in the morning my belts squeek really bad and its really annoying. Anyone know how to make them stop squeeking?
Old Mar 13, 2007 | 02:42 PM
dhg2496's Avatar
Is your AC running? Our RX 300 has been doing this because the AC Compressor is sticking and the belt is forced to slide over the pulley.
Other than that, have you looked at your belt? Is it getting old or worn out? Maybe you should replace it before it does what your GTP did to it's belt.
Old Mar 13, 2007 | 02:53 PM
Knight's Avatar
Yeah i checked the belt and it was fine..i think the reason the GTPs broke is because radiator fluid was leaking from the water pump on it all the time.
No i rarely use my A/C so i don't think thats it. But it only happens when it rains or when its kinda wet out. The belt looks aligned just fine and the belt is tight and looks fine. But i can't stnad the weeeeeeeee weeeeeEEEEEEeeeeeeeEEEEEeeeee WeeeeeeeeeEEeeeeeeeeeeee.
Old Mar 13, 2007 | 05:51 PM
future9er24's Avatar
The mazda did that alot in the months prior to its alt belt snapping on me. But you said yours seems fine...
Just WD40 it
Old Mar 13, 2007 | 07:02 PM
1 COBRA's Avatar
Could be a pulley. Also, if the belts are over four years old it might be time to replace them.
Old Mar 14, 2007 | 04:34 AM
tricky02GT's Avatar
PB Blaster. Will last longer than the WD40.
Old Mar 14, 2007 | 06:39 AM
dhg2496's Avatar
My guess is that they are the original belts so it would probably be worth while to change the belt and see if it fixes the problem. Then you could at least rule that out if it doesn't fix it.
Old Mar 15, 2007 | 04:13 AM
Knight's Avatar
yeah after what george said made me think it is prob best to replace the belt since it is prob the one from 1998 since its a 1999 model year.
Old Mar 16, 2007 | 09:03 AM
cliffyk's Avatar
Get a Goodyear Gatorback, or Dayco PolyCog -- Advance/PartsAmerica can ussually get the PolyCogs in the same day if they don't have it in stock...
Re: WD-40 or PB, you should never use any dressing on an automotive belt (or really on any V-belt), all it does it mask the symptoms of other problems (also, petroleum based things are the worst you could use, they will degrade the rubber and only quiet the belt because now you've lubicated the slipping).
Belts are noisy because they are misaligned, improperly tensioned, or worn and/or hardened from age--fix the problem and you won't need to squirt crap on it every now and then...
Old Mar 16, 2007 | 09:05 AM
Knight's Avatar
thanks, my first plan of action is to buy a new belt.. then i'll see if that fixes it or not. tomorrow..off to the auto store!
Old Mar 21, 2007 | 06:33 PM
cliffyk's Avatar
Did a new belt fix things up (I mean quiet 'em down)?
Old Mar 21, 2007 | 09:42 PM
Knight's Avatar
yep after my little hicup here. http://forums.bradbarnett.net/showthread.php?t=62268
The new belt did do the trick. perfectly silent in nice weather and then it also poured rain today and it was also silent!
Thanks everyone.. guess always start with the basics.
Old Mar 21, 2007 | 10:02 PM
hi5.0's Avatar
Don't you just love cheap, simple solutions? BTW, you should use the a/c periodically so the compressor doesn't go to crap and to monitor it to make sure it's in working order for when you really need to use it.
Old Mar 21, 2007 | 10:08 PM
cliffyk's Avatar
Cool, glad you got it quieted down!
+1 on the AC, it needs to be exercised once in a while or it will develop problems...
Old Mar 22, 2007 | 11:46 AM
dhg2496's Avatar
I think for Chris he's more likely to remove the AC just to save weight than to actually use it.
Old Mar 22, 2007 | 04:29 PM
Knight's Avatar
I so want to strip a bunch of stuff out of my car but i know if i did joann would no longer ever want to ride in my car or take it anywhere.
I need two mustangs
Old Mar 22, 2007 | 08:28 PM
GottaHaveIt's Avatar
Hey Chris My X just had the same thing on her 2003 Ranger she has a 3.0 litre engine, so I took it to Ford for an oil change and looky loo, they said the belt coud be replace as well the tension pully, ok so I ordered said parts put them on and still had a chirp ?? so I replaced the other free spinning pully, still chirp Then it hit me !
There is a diagram on the front plate on top of radiator, that shows on size of engine as to how the serpintine belt should be threaded ! I replaced the same way thinking it was correct , It was not so if squeek when belt off and engine spin pullys and you should be able to tell on them and view your belt for wear as well on properly. that is my 4.5 cent worth I do hope its of some use. ED
Old Mar 23, 2007 | 05:22 PM
dhg2496's Avatar
I need two mustangs
Sg\he doesn't really need a seat in the car does she?
Detroit Steel
Ecoboost
19
Jul 17, 2016 05:54 PM
GTPETE
Oct 12, 2015 02:20 PM
dave07
Oct 4, 2015 06:07 PM
nismos13s14
1994-2004 V-8
Jul 31, 2015 12:55 PM
