This could be a problem..
Old Apr 7, 2012 | 09:37 PM
cpotts13's Avatar
Alright, i had recently installed lowering springs on my 2000 gt, and after ahwhile of driving i was noticing alot of squeaking and clunking.. i went and double checked everything, the control arms cleared the exhuast.. but then i saw it.... some how the driverside bolt that connects the shock to the axle had lost its nut.. so only the bolt was there.. my question is... what size bolt and nut would i need? Should i just go to the hardware store and buy one? I checked online and the only thing i found was the bolt size(?) 12mm x 1.75 x 70mm, would it be okay to get that and a nut that fit it?
Old Apr 7, 2012 | 09:57 PM
grabberblue 5.0's Avatar
Take the same nut off of the opposite side and match it up
Old Apr 7, 2012 | 09:58 PM
cpotts13's Avatar
this is true.. .
Old Apr 9, 2012 | 12:04 PM
1999Pony's Avatar
Originally Posted by cpotts13
this is true.. .
Old Apr 9, 2012 | 01:23 PM
cpotts13's Avatar
Originally Posted by 1999Pony
Fixed, solved all the squeaking and rattling.
Old Apr 9, 2012 | 02:40 PM
Good, what was the cause?
Old Apr 9, 2012 | 03:01 PM
cpotts13's Avatar
the bolt holding the driverside shock in place was missing its nut, so it wiggled around a bit.
Old Apr 10, 2012 | 11:57 AM
1999Pony's Avatar
That's how mine is. The nut won't stay tight on the driverside uca. I've tightened it twice, but now I just don't care since I have the torque arm and panhard bar going in within the newt 2 weeks.
Old Apr 10, 2012 | 12:14 PM
Lock washers
11SHELBYGT500's Avatar
Lock washers
Loctite??
Old Apr 10, 2012 | 12:15 PM
Or both and that sonofa***** will never come loose again. Gonna need a cutting torch lol
Old Apr 10, 2012 | 12:20 PM
1999Pony's Avatar
Lock washers
Loctite??
Its already a nylock nut that apparently doesn't work very well
Both the uca's are coming off soon enough anyways though.
Old Apr 10, 2012 | 01:11 PM
cpotts13's Avatar
This is what i did.
Liamnacuac
Jan 3, 2014 05:25 AM
Kript2night
Aug 20, 2013 03:54 AM
Sixpac
1994-2004 V-8
Jun 26, 2013 12:55 PM
DEPUTY62
Nov 8, 2009 05:58 AM
ocean1
2007-2009 Mustang GT/CS
39
Nov 16, 2007 08:56 PM
