CHIPPED?
Old Jan 22, 2006 | 06:58 PM
tricky02GT's Avatar
How would I know if my new car (yesterday) is chipped?
Old Jan 22, 2006 | 10:15 PM
Mestizo's Avatar
I guess to answer your question with a question.....huh?
I guess if you're talking about performance chips....it should be on the passenger side kick panel.
Old Jan 23, 2006 | 12:05 AM
J2D's Avatar
J2D
If the computer has been reflashed, one way to find out is to have it dyno tuned, they could tell you if it was stock or flashed.
Old Jan 23, 2006 | 06:51 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Well if its got a phsyical chip in it, you can easily tell if you pull the passenger side kick panel off, then undo the wiring harness's, then pull the ECU out from behing the black bracket. Its tricky the first time, but no big deal. On the top of the ecu is a port where a chip would be hooked to. If its got something sticking out of that port, its got a chip, if it has a plastic plug over the port hole, then it doesnt. If you can pull the plug off the hole and look in and see the connector, then it doesnt have a chip.
The other way as Matt mentioned is it may be reflashed. Its not easy to tell on this, but you may can take it to a mustang shop and see if they can pull a reading off it or something. An Autotap may also let you know.
Old Jan 25, 2006 | 05:32 PM
tricky02GT's Avatar
Its chipped. Explains a few things, thanx for advice folks.
Diode Dynamics
Jun 12, 2018 03:26 PM
Diode Dynamics
Feb 28, 2018 09:37 AM
radio
Sep 17, 2016 03:37 PM
Mr. V
Nov 22, 2015 06:31 PM
JonathonK
Jul 15, 2015 07:53 PM
