CAI stuff
Old Dec 20, 2005 | 01:27 PM
RFX_Bass's Avatar
well i was visiting my mechanic today for oil change and all, and he told me insted of installing the K&N filter u should use the stock one drill a 2.5 hole and put hose a from the stock air intake to the back of the front griil, is this true? or that with the CAI that i already have install, i should sorunded the arm with heat resistant material so the air that goes to the manifold doesnt get heated with the heat comming from the engine..
just some questions!!
Old Dec 21, 2005 | 07:51 AM
J2D's Avatar
J2D
That sounds like a load of crap. The benefits of a CAI are the smoothflow piping and drawing air from the fender well.
Now I don't see a problem with adding a hose from the grill to the CAI, but if you have to many bends and kinks in it, it isn't going to perform well at all. Plus the CAI gives a much cleaner look.
Old Dec 21, 2005 | 08:03 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
I see a problem with adding a open hose straight into your intake tube.
If you run it without a filter, its gonna suck in dirt, water, etc and get that into your engine. Thats a nono in its own.
The 2nd problem I see is where are you going to connect said hose at? Better be before the MAF because if you dont, you are going to introduce alot of un-metered air into the engine, and 1, it may not run at all due to it, or it will run amazingly lean since the MAF does not know to compensate for the extra air and add fuel.
Yeah thats a stupid idea completely.
Also with the heat resistant material, air is moving through your CAI so quick that it really doesnt have a chance to heat up. Sure it makes sense, but the air in a intake tube is no where near dorment, its constantly pulling through at a fairly high rate of speed. Thats at idle, if you are acctually moving with the car, the air velocity increases with RPM and also wind blowing up from under the car and through teh grill will provide enough to keep any significant heat away from the intake tube.
Old Dec 21, 2005 | 10:26 AM
RFX_Bass's Avatar
wee he said with the stock filter and the hole would be under the filter, he said something liek, that air box presuraise the air or something,
but i dont think il be visiting that mechanic again....
Old Dec 21, 2005 | 11:20 AM
RFX_Bass's Avatar
aa crap talking aobut cai, i was cahging the filter, and one of the rubber fitting just broke dog gone! i put some ducktape to holde the 2 tubes together, i hope it hold utill i get it to he shop tommorow
14_GT/CS
2011 - 2014 GT/CS
12
Mar 24, 2016 12:20 PM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
MustangConvert11
Sep 30, 2015 08:01 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
TripleBlack14
Sep 17, 2015 07:48 AM
