Brake caliper 04 gt
Old Apr 4, 2011 | 04:43 PM
SVTCobraR315's Avatar
Brake caliper 04 gt
So my front right caliper is seizing. Never replaced a caliper. Any tips?
Old Apr 4, 2011 | 04:57 PM
it should be pretty straight forward. just make sure you bleed the brakes well.
Also, pick up a repair manual if you dont already have one.
Old Apr 4, 2011 | 05:20 PM
Should I get that bleeder tool from steeda or something?
Old Apr 4, 2011 | 06:26 PM
cntchds's Avatar
Nope, just buy one from any auto parts store, and have a buddy with you to push the brake while you open/close the bleeder valve until the bubbles are gone. Make sure you constantly fill the brake fluid or you can get air into the ABS and need Ford to bleed that out. Just be careful and everything should be good. Are you replacing the line as well, or just the caliper?
Old Apr 6, 2011 | 09:18 PM
^good point. It may be a good occasion for you to replace the brake lines, since you have to bleed the system anyway
Old Apr 10, 2011 | 06:48 AM
It doesn't seem that difficult. Just gotta watch for air in the lines? I'll keep you guys posted. Had to buy new tires first :-). She still brakes just fine. Just a bit squeaky.
Old Apr 11, 2011 | 12:26 AM
cntchds's Avatar
If it's just squeaking I would try to change the pads before doing something extreme like changing the caliper. I just upgraded to Cobra fronts, and they are squealing up a storm under low speed braking. I put on new cheapo pads, but now I'm looking into some decent pads so I can hopefully eliminate that.
Old Apr 11, 2011 | 02:59 AM
Just put new pads and rotors on.
Old Apr 11, 2011 | 10:25 PM
cntchds's Avatar
How did you break them in? Improper break in can cause glazing on the pad which causes that squeal. Just trying to help you out, because it would suck to change the caliper, and it just be the pad.
http://www.stoptech.com/tech_info/wp_bedintheory.shtml
Old Apr 11, 2011 | 10:31 PM
Def. break them in right! and it'll still be a bit before they truly bed in and give you max performance.
I love the Hawk HPS's that I had!
Old Apr 17, 2011 | 03:14 PM
Onesickstang01's Avatar
Try to compress the piston in. If it goes in then the caliper isnt freezing up. Now try to slide the slide pins in and out. They shoild glide easily. I have a feelin that is your problem. If not either of those problems your rubber brake lines may be breaking down inside and causing blockage. Normally you can tell wjen this is happening because you can feel your brakes dragging
joemad59
Dec 30, 2015 06:13 PM
boz
Oct 1, 2015 04:47 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
