Battery Shutoff Switch?
I'm looking for some advice/help with a battery kill switch. I've solved my electrical issues enough to the point that I can leave the car alone for a day or two and she won't be dead, but any longer than that and the battery is low.
Any time I park her for longer than a day, I just disconnect the battery. Well, I'm getting annoyed with that whole process every time I go out, and want to install a battery kill switch in the car.
Here's what I'm looking at from American Muscle, http://www.americanmuscle.com/taylor...isconnect.html
Will this do the job? I should connect it to the negative side to avoid shorts correct? And, can I just put it as the middle man somewhere along the main negative wire?
Any pics, or info. would be greatly appreciated. Thanks!
If you are really serious about it, what I would do is move my battery to the trunk and install a kill switch to the exterior of the car. There are a lot of write ups on how to do it, and a few switches allow for the switch part to be removed so it isn't hanging off the car all the time. I would then just use that to fully shut off the battery rather than putting it under the hood, but I guess if it's only every few days it wouldn't really have to be that prominent.
Just do a Battery Tender. They're around $30.00 and there's no automotive "reprogramming". My car is sucking on one as I type...
http://batterytender.com/
I've never seen one on the dash like that. Maybe a solenoid that controls the real cut off would work, but I think it would take a whole bunch of work to run the wire so that it could be physically cut off in the cabin...
Do you have any references for a setup like that, that I could check out? (I hate dealing with electrical stuff, partly why I'm trying to gather so much info. on this) Thanks!
Here's a bunch http://www.summitracing.com/search/?...20switch&dds=1n mount it on a frame rail or behind the grille for that matter, and they should have instructions w/tech support.
http://www.amazon.com/gp/product/B00...D442DK9481081Z
Comes with a remote to disconnect and reconnect the battery without popping the hood.
http://www.summitracing.com/search/B.../?autoview=sku
That is an example of a switch in the cabin like I was thinking of before. Price seems similar, and you can't lose a switch like you can lose a remote.
http://www.watsons-streetworks.com/battery.html
This one has a couple more stealth options...
I know that he at very least posted a thread about his battery drain problem. It seems to me that he either gave up, or it wasn't worth fixing the correct way, and this would be "enough."
Although I agree with you Patrick, I have been in that position where fixing it the right way is a whole boatload more complicated than just fixing the problem.
Long story short, I would love to fix it... if I had any clue what to even fix.
Haha man that sucks big time. I hate electrical issues in cars (modern cars at least. They're so hard to solve. I figured you at least tried...and yeah at that point I think I'd justto the route you're going. Good luck bud!
