Anyone know what this is?
Old Oct 26, 2006 | 09:57 PM
PaulF's Avatar
It wasn't my brakes that were the problem....The problem was this peice of metal (which I'm assuming is a heat shield) had its rivits sheared off and was loose, rubbing up against the rotor.
http://www.putfile.com/pic.php?img=3812504
As you can see, there isn't any damage to the metal, other than the contact with the rotor:
http://www.putfile.com/pic.php?img=3812505
A little closer of the damage to the metal:
http://www.putfile.com/pic.php?img=3812506
Can anyone correctly identify this part and more importantly, do I really need it? And if so, any clue on how to re-attach it? There aren't any points to screw it back into, it was definately three rivits...
Old Oct 30, 2006 | 06:15 AM
98YELLOWGT's Avatar
Cool
Thats your dust shield...it helps keep dirt and crap off the brake rotor.
Rivet it back on....I thought they were bolted on though.
Old Oct 30, 2006 | 07:02 AM
PaulF's Avatar
Thanks! It's definately not bolted on, as there isn't anywhere to bolt it to, that I could find. I'm going to rotate my tires this weekend, so I'll double check it.
Thanks again!
Old Oct 30, 2006 | 04:22 PM
tricky02GT's Avatar
Did you pull it off or did it kind of fall off?
Old Oct 30, 2006 | 07:29 PM
PaulF's Avatar
A little of both....It was just kinda swinging in the wind, knocking against the rotor. When I got the wheel off, I tugged on it slightly and out it came! Definately not attached in anyway.
Old Oct 31, 2006 | 06:57 AM
DrunkenDragon713's Avatar
Might just be a loose clamp that after driving for so long, just starts falling apart. I agree with 98YELLOWGT, it's the dust gaurd. I just got old and fell off.
