1994 Mustang Transmission swap HELP
Old Mar 5, 2018 | 03:41 PM
Jpooler0821's Avatar
So for the last couple years I have been collecting the parts necessary to complete this frankenstein swap. It was originally a 1994 automatic 5.0, I took the 5.0 out and put in an S281 motor, and swapped from the auto to a T5 from a 2002 GT. The problem I'm running in to right now is I can not find a transmission cross member and transmission mount that will fit. Has anyone done a swap like this that can point me in the right direction for a solid cross member and transmission mount?
Old Mar 16, 2018 | 01:37 AM
cntchds's Avatar
If you haven't already, I'd reach out to Maximum Motorsports. I think they should be able to give you an idea if the mounts were in the same place. If they are, you should be ok just picking up a transmission crossmember for a 96-00.
Also, not sure if it matters, but 2002 GT's had a Tremec-3650, not a T5. Might have a different mount, because if memory serves it was a bit heavier than a T5. I'm pretty sure the V6 was still running the T5, though, so maybe that's what the tranny came from?
pushrodvert
1994-2004 V-8
Sep 8, 2014 08:41 AM
94 5.0~HO
1994-2004 V-8
Aug 29, 2013 08:54 AM
Jake_B_Chillen
Apr 16, 2013 06:14 AM
05BlackVert
V6 Performance Mods
Nov 7, 2005 04:02 PM
rrobello
1994-2004 V-6
Jul 1, 2005 10:56 AM
