Wiring for XM Radio
I am installing a Roady2 XM radio and would like to be able to hook it to a power source that operates like the factory radio where it stays on for a period of time after the key is shut off or until you open the door. Has anyone done this yet?
I did this for my auto-dimming rearview mirror. If you check your owner's manual there's a fuse in the passeger side kick panel fuse box for "accessory delay" or something similar. Tapping that circuit will get you the "delayed off" power.
Originally posted by CANES fan@August 5, 2005, 9:13 AM
What are you using to hard wire the Roadie 2 and are you doing it yourself? I just got the receiver and will hopefully be getting the Stang soon. Let me know how it goes.
Originally posted by yellow05gt@August 5, 2005, 11:38 AM
I bought a power outlet from Radio Shack and then wired it into fuse location #6 in the passenger kick panel.
Does anyone know which color wire to tap into to get the radio power from fuse 6?
Sounds like you could help out a bunch of people with a how-to with some pics. Just a sugestion if you're not too busy to do it.
Originally posted by tx_pony@August 7, 2005, 11:31 AM
How did you wire it into the fuse location? I bought a mini-fuse tap but it is too large to fit into molded opening for the fuse prong.
