Is there a Navigation unit that is plug-in...
Old Dec 16, 2004 | 06:51 AM
r22tech's Avatar
Anyone know of a navigation unit that would simply plug into the outlet on the dash in such a manner as to put the screen between the two a/c ducts above the outlet? I'm talking about something like the cell phone holder/chargers that are a one piece unit: the holder has a plug and is shaped like an "L" in which you just dock your phone onto the bracket that is plugged into the outlet...no wires.
Old Dec 16, 2004 | 09:45 AM
r22tech's Avatar
Bump
anyone at least know what i'm talking about?
Old Dec 16, 2004 | 09:50 AM
78Mach1's Avatar
Sirius Sat. Radio is coming out with one
Old Dec 16, 2004 | 09:59 AM
r22tech's Avatar
I'm taliking about something like this, only for a portable Navigation unit...
Old Dec 16, 2004 | 10:30 AM
Wolfie351's Avatar
Not going to happen, the GPS unit needs to be on the dash with a clear view of the sky. No self contained GPS unit that I know of has a corded external antenna. I use my Ipaq PDA for gps use. Has a lot more functions and is easier to use, the only drawback is the screen size is a bit smaller.
Old Dec 16, 2004 | 10:43 AM
Montrose's Avatar
I have a navigation aide that folds up and goes in the glovebox when I am done with it.
Old Dec 16, 2004 | 10:55 AM
justme97's Avatar
You can do this if you are using a pocket pc based gps system which imho is the cheapest, most flexible way to go and works great. Check out http://www.arkon.com/ ...they have a unit I bought that holds, charges, and amplifies the sound of the pocket pc.
As for line of sight you just get a blue tooth pocket pc and a blue tooth gps reciever (I have the belkin one) and wirelessly mount the gps part on the dash for line of sight to the sky.
ps-www.gpspassion.com is a great place to go for anything gps...
Old Dec 16, 2004 | 12:17 PM
lwing18's Avatar
I think there are several units. Cobra, Magellan, Garmin might have what you need. The garmin 3600 (looks like the one pictured by justme 97) can plug into the dash plug, and sit on the dash. They have an accessory holder for the top of the dash that just sits on the dash.
But, from displays I have seen at best buys or circuit city; it looks like the plug in units will fit in the location you want; just not sure how big they are relative to the space you have. A question might also arise of how to locate the antenna. the 3600 is built into the unit; no additional wires. Other units require location of an antennae.
You should also look on crutchfieds. They probably have some units.
Old Dec 17, 2004 | 05:59 PM
mrv8outboard's Avatar
this thing works great used it in florida on a trip and around here at home. i can get these.
http://www.avmap.it/index.php?sec=1&sub=10&lang=en
duppycat
Feb 16, 2019 08:36 AM
OneCoolGT
Dec 10, 2015 07:55 PM
Steve@CJPP
Sep 24, 2015 06:58 PM
50Cal
Sep 16, 2015 03:54 PM
