Shaker Subs w/Aftermarket HU & Amp
![Question](https://themustangsource.com/forums/images/icons/icon5.gif)
I told you guys I wasn't up on all the intricacies of the aftermarket audio systems, but dammit I will do this install one way or another ![Smile](https://themustangsource.com/forums/images/smilies/smile.gif)
Would this be the correct way to wire the Shaker Subs to an aftermarket H/U with an aftermarket sub and amp? The Shaker 500 Side is the Metra Wiring Harness for our cars (pictured below), so it would have the factory wiring after the harness. To the Aftermarket Sub Amp would be RCAs and the Red & Blue Lines are the Y-Adapters.
Also this would be the Subwoofer Pre-amp from the HU.
Attachment 8200
Attachment 8201
Attachment 8200
Attachment 8201
Almost. On the Metra harness, either of the RCA's go to one amp (mono signal). I can't remember which color is front/rear. Put your Y on one of those, and run that to an amp. Don't split the signals. If it isn't making sense, I'll edit your pic in a little bit.
I don't want to hook the Factory 8s to an aftermarket sub. I already have an aftermarket sub running a 12" sub in the trunk.
I just want to run the factory 8s off the HU using the existing factory amps. (Eventually will replace them when a good fitting sub is made if ever)
Is that even possible?
Here is a picture I did of what I want to do. (if it is clear enough to read, I have it in excel if you want it in that form.)
I have the amps installed and the Driver side wires etc ran.
The only thing I am unsure of is the factory 8s, I am not for sure how they are wired or if the amps are on one side or both sides.
Attachment 8252
With you now. You'll only use ONE of the RCA's in the harness, with a Y on it to connect to the stereo outputs on your new head unit. Like I said, I cannot remember which color it was, but I THINK it was the red one. Obviously, if that one doesn't work, use the white one
The amps are located in the driver's kickpanel. The one closest to the door runs the passenger woofer. You won't have to mess with them, as everything will run from the harness. The only issue you may have is a turn-on noise in the 8's. It won't hurt anything, but if you have the problem, LMK, and I'll wak you through fixing it ($2 fix to do it correctly).
Sorry I am so stupid on this I just don't want to screw up any of my equipment
You might need to draw me a picture
![Roll](https://themustangsource.com/forums/images/smilies/roll.gif)
The HU has 3 pre-amp outs front/rear/sub I have all three of those taken up; the front & rear by the 4-channel amp and the Sub by the Mono amp.
I would need to connect the 8s to the HUs sub pre-amp right ? or am I just totally lost
The 2 amps that run the 8's are both fed signal from the red RCA jack. The white one fed the signal to all 4 of the S1000 amps- if equipped. So, the red jack needs to be attached to your head unit, be it front/rear/sub, that's up to you. It's all in how you want to control them.
So now I still have the question of whether or not I can run the 8s and the 12 off the same SUB pre-amp from the HU without hurting anything.
Ok, after I thought about it for awhile, I believe this will work. Since I am just splitting the SIGNAL this shouldn't affect anything, right? If I am wrong PLEASE let me know.
Attachment 8288
If this doesn't work at least I am getting some drawing practice
Attachment 8288
That will work. BTW, your drawings are nice. They're clear and concise.
forceflow2
'10-14 Interior and Audio
8/4/15 08:02 PM
