Shaker Head Unit Removal?
Old Jun 22, 2005 | 03:40 PM
baloyinc's Avatar
Does anyone know how to remove the stock head unit (Shaker 500 or 1000) in order to install and aftermarket head unit (Sony, Kenwood, Alpine & etc.)?
If yes, can someone please post a few step-by-step instructions and/or photos of how to get the bezel off safely and easily?
Old Jun 22, 2005 | 03:49 PM
hawgman's Avatar
1) Open the center console. Remove the two phillips head screws at the back of the console opening ( on top ).
2)Pull emergency brake all the way up.
3)Lift the console cover up, pull back, and work over brake handle
4)Remove screw on each side of lower center console that was covered up by the center console cover you just removed. These screws will be where the two consoles meet.
5)Remove side cover from each side. They just pop off.
6)Remove 6 bolts holding on faceplate. Unplug airbag, power port, and flashers. Unplug fan and climate control plugs. Remove face plate.
7)Remove 4 bolts holding radio in place.
Turn the directions upside down to put it all back together
I have the Ford documents in PDF format on removing the console, console face plate, and radio if you want to shoot me a PM with your email addy I will send them to ya. But it is pretty straight forward.
Old Jun 23, 2005 | 01:17 PM
tmcolegr's Avatar
part 1
Old Jun 23, 2005 | 01:18 PM
tmcolegr's Avatar
part 2
Old Jun 23, 2005 | 01:19 PM
tmcolegr's Avatar
part 3
Old Jun 23, 2005 | 01:23 PM
ChrisM's Avatar
See the thread below for all the do-it-yourself details. Good luck!
http://forums.bradbarnett.net/index.php?showtopic=19792
duppycat
Feb 16, 2019 08:36 AM
NC14GT
Sep 10, 2017 04:47 PM
Sep 30, 2015 07:02 PM
earl610
Sep 7, 2015 11:57 AM
