shaker 500 removal? (delete)
Old Jan 28, 2011 | 07:10 PM
impetus maximus's Avatar
Question shaker 500 removal? (delete)
howdy folks
looking to shed some weight and save my battery. any issues running without the radio/amps?
guidance/tips for taking it out would be most appreciated. i will disconnect the battery before i start.
thanks
Old Jan 28, 2011 | 09:58 PM
Cavero's Avatar
I seriously doubt you'd have a problem without having the radio installed. As far as taking it out goes, it's fairly easy. Take out two screws from under the center console, then most of the dash comes apart with spring clips. The radio itself will be held in with 4 hex head bolts. Try this link:
http://www.allfordmustangs.com/forum...o-removal.html
Old Jan 28, 2011 | 10:04 PM
thanks for the info
[edit] "NOTE: Prior to removal of the audio unit, it is
necessary to upload the audio unit configuration
information to the diagnostic tool. This information
needs to be downloaded into the new audio unit
once installed. For additional information. refer to
Section 418-01."
taken from here found in this thread. i'm guessing this is a security feature
wish i could get a hold of that PDF manual
[/edit]
duppycat
Feb 16, 2019 08:36 AM
Cobiecane
Oct 23, 2015 08:44 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
