Shaker 500 Amp
with an after market radio it would be simple, just hook up the amp and run speaker wires to the door subs
remember just about anything is possable with the right know how
good luck and keep us posted
I'll let you know eventually. I will be doing just that before too long. I will need to add a nice amp to drive the front speakers I want to add and then add a big amp to drive the sub box I will make. The sub should be easy as the wiring is already there and the factory sub uses an amp. The only trick is going to be providing the proper turn on signal for the aftermarket amps.
Steve@CJPP
9/15/15 06:20 AM
