Shaker 1000
Old May 15, 2005 | 07:38 AM
tmcolegr's Avatar
No matter where I posted this question, (performance or audio) it would be to the wrong group - but here goes. I have a Predator C&L Custom Tune in my Mustang. This week the vehicle will be going in for the TSB on the front strut popping and to have my Shaker 1000 replaced - both known issues.
Here's my concern. Prior to replacing the Shaker 1000 head unit the data from the existing head unit must be downloaded and installed into the new head unit. How is that done? Can't be through the OBD-II diagnostic connector. I don't really want to flash my vehicle back to stock just to have the radio head unit replaced. Does anyone know?
Old May 15, 2005 | 08:07 AM
hawgman's Avatar
I have never flashed my car back to stock to have the Skipper1000 replaced. I don't know where the d/l the info, but you don't have to reflash.
Hope the replacement works out for you. I am on my 4th one, last two have been "B" series, it is still a piece of $hit. I gave up on getting them replaced and am now installing an aftermarket unit.
Old May 15, 2005 | 08:46 AM
Tiberius1701's Avatar
All vehicle bussed communication is performed through the DCL connector with the WDS scan tool.
When the radio data is downloaded it is done on a "menu driven" basis, that is the scan tool is working only within the audio section of the data bus. As long as the tech is only in that section your flash for the tune will not be affected.
Old May 15, 2005 | 10:29 AM
tmcolegr's Avatar
Matt - Thank you very much! I will post your answer on the performance section as I posted the question there as well. Sounds like some others are giving me "the deer in the headlight look" when I asked this question.
So basically as long as they stay in the audio menu I should be good to go - correct?
Old May 15, 2005 | 02:51 PM
Yessir!!!
Old May 15, 2005 | 03:17 PM
flamin ponyexpress's Avatar
Originally posted by Tiberius1701@May 15, 2005, 2:54 PM
Yessir!!!
I'm on my 2nd shaker 500. I know when they replaced my stereo in order to get the lights to work on the radio, they had to program the computer, the tech at ford said that he has never had to program a computer before to get the radio to work right, until now. They where about to take it out when they called ford and ford told them to reprograme the computer. Even the people at the dealers don't know a lot about the 05. good luck.
Old May 15, 2005 | 06:47 PM
GottaHaveIt's Avatar
I've had my Shaker for about one month now and there are so far only two things the time it takes to load/read a cd and some that I rip at home will read as a BAD CD and as far as I can figure that the copy right issues must also stay attached ? so if you buy music be it in Canada ( Pure Tracks ) or the USA ( Music Match ) you sould have the right to rip a copy for your personal use :scratch:
Old May 17, 2005 | 11:56 AM
hawgman's Avatar
Have you tried the ripped copies on a different system? If they play there, it's your Skipper that is the problem, not your copies. I am on my 4th one, it is about to become a fixture in my attic. I am tired of it. This last one will play any disc fine while it is cool. Park the car in 80 degree sunlight for a couple of hours and it will spit out disc as soon as you power it up.
duppycat
Feb 16, 2019 08:36 AM
Fedupdave42169
Sep 22, 2015 06:29 PM
scott6809
Sep 12, 2015 11:44 PM
