selling some audio stuff out of my car
Old Apr 19, 2006 | 02:51 AM
vc4life's Avatar
im going to be downgrading so to speak from the 4 db drive 12's in the mustang to just 2 db drive 15's so i am selling the 4 12's and the 2 sub amps
heres the deal
4 pl12d4 750w rms 1500 peak
2 pd1200.1 1200w rms at 1ohm at 12.5volts
the 12's i will let go for 250 each or 225 each if you buy all 4 at once
the amps will be 500 each or 475 each if you buy both
shipping will be calculated by your address and i use ups ground and i always over pack anything i send
out to make sure its safe
if you have any questions please ask
this equipment is all top of the line no BS, thats the reasoin it was in the car and why i will continue to use this brand
here are the specs for the amps
PD1200.1
Class D technology
1 x 300 watts
1 x 600 watts
1 x 1200 watts
20 - 50Hz
1 ohm mono
15.125 in
10.3 in
2.25 in
Features:
* 2 and 4 channel 4 ohm bridgeable
* Tri-mode capability (PA475 & PH700)
* Continuously variable 12dB boost on bass equalizer
* Continuously variable 12dB per octave highpass and lowpass crossover (3 & 4 channel)
* Continuously variable 18dB per octave lowpass crossover (class D amplifiers)
* Variable subsonic filter (class D amplifiers)
* Direct connect integrated speaker and power wire terminals
* Double sided PC board
* DC-DC PWM power supply
* Bipolar outputs
* Buffered pre-amp input circuitry
* Buffered line out for easy "daisy chaining" of amplifiers (class D amplifiers)
* Multi-Link capability on class D models (no bridging module required)
* DriveSink heat management system
specs for the subs
SUB SPECS AND PICS
PL12D
12" dual 4 ohm voice coil
1500 watts
750 watts
88dB
180 oz.
Features:
* Multi-layered poly-injected cone
* "Overdrive Assembly" one piece gasket surround
* Four piece rigid dustcap design
* 3" diameter, high temperature 4 layer voice coil
* Extreme excursion motor structure & suspension
* Black treated anti-resonanse die-cast aluminum basket
* Spring loaded push button terminals
* Fully isolated high excursion tinsel leads
Old Apr 23, 2006 | 08:03 PM
vc4life's Avatar
friendly bump
jc46002003
Apr 15, 2016 03:00 PM
Bullitt 3309
Aug 2, 2015 10:20 PM
roushcollection
Jul 28, 2015 02:08 PM
