Seat Removal
Has anybody removed the driver or passenger seats from their 05/06 GT. I got a deal on some Sparco racing seats, but there may be a problem with the airbag sensors in the stock seats.
Need to know if anybody has figured out a way to disable the sensors, but still have the air bags work. (The air bags in the car, not in the seat)
Any help would be appreciated.....
I wouldn't mess with those sensors. They're very sensitve, and unless you can mount them inside a seat with the same foam density and dimensions of the OEM seat I wouldn't touch em. Those sensors classify who/what is sitting in that seat by downward weight and weight distribution, & tell the airbag how many stages to fire, how quickly to fire, etc. If you REALLY want those seats, take your car to a professional and have them either install the sensors or bypass them...don't try yourself
This isn't the same question, but it's related. I spilled something (I know, I will never again have a drink in my car) down on the right side of my drivers' seat. What exactly does it take to remove the drivers seat, so I can get at the carpet underneath to clean it all? I see some bolts on the rear part, but if anyone could give me more specific directions, that'd be cool.
I guess I don't need to remove it entirely, I just need to lift up the seat so that I can get at the carpet. Any tips? Recommendations on the best way to clean the carpet? I used Maguire's leather cleaner on the seats immediately, so that's fine.
Those seats look fabulous !! I'm curious... as I'm interested in what it takes to deal with the occupant sensors in the passenger seat... were the Sparco seats already equipped with sensors... and if not, how difficult was it to deal with the stock sensor ??
Looking to install a set of racing seats in the future...stock ones aren't cutting it during HPDE days...
If I remember correctly there are four bolts per seat and mine had two sensor plugs, one for the motors and one for the airbags. If you plan on pulling the seats all the way out, get some help they are alot heavier than I thought they would be and I messed up my scuff plate. You can however get the seats and carpet really clean with the seats out.
The side airbag sensors are NOT in the seats themselves. From what I have read about side air bags, the sensors are either in the door or on the frame rail. If you think about it, having the sensor INSIDE the seat proper would not provide much protection... the impacting vehicle has already breached your door and is hitting the seat!
In this pic of my vert, the green circle shows what I believe to be the side impact sensor. The red circle shows the power plug for the airbag itself. Only your dealer can tell us for sure.
Specifically I'm concerned about how to keep the occupant weight sensors active. These will control how forcefully the dash and steering wheel airbags deploy (if they deploy at all).
Are those sensors in the seat rails, or in the seat bottom, or what?
Looks like on the PDF that # 4 on the passenger side seat ( OE OCS ) is the sensor, and it looks as if if goes between the cusion fram and the cusion. Dosnt look like theres anyways to get this to work out....
