Satellite Audio FM or Not
I have the Shaker 500 in my 06 GT and also a Sirius receiver using the FM demodulator. I have interference problems no matter which of the 3 available FM frequencies I use, and I would like to go direct to the Shaker using the aux input. Also, I am thinking of replacing the the Shaker with a Sony aftermarket unit that has both an equilizer, which I think the Shaker sorely lacks, and a front panel aux input. All the big box stores seem to have attractive prices, and free installation. Any ideas for $200 or less to upgrade the GT audio system considering my Sirius receiver as part of the mix?
That seems a tad high, i bought my modulator from PIE for around $70, install at a local audio shop yesterday was $77 plus i forgot to bring my RCA's and had to buy what they had in stock (monster cable with seperate i-pod inout) for $39.95---that being said, direct connect blows away FM modulation, it is well worth no have the frustration of a crappy signal--for the record, it sounds stellar--at any rate, install should run you no more the $75-$80 bucks if you bring the the adapter and RCA cables. Good Luck--install took them about 2 hours--
Originally posted by KR3259@December 31, 2005, 9:20 PM
if you are going for an aftermarket radio just get a sirius ready unit and your problems are solved.
I just bought the PIE interface for mine...going to put it in monday
Thanks for the replies.....
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
