Saleen Switch Plate
TMS West Coast Correspondent
Saleen Switch Plate
Has anyone painted their door switch plates silver like they are on the Saleens? If so could you please post some pics and what paint you used?
thank you
thank you
I did mine as well but no pics at the moment. Also used Duplicolor spray can bought from Pep Boys. I scuffed the plates with 600 grit sand paper and put down 5 or 6 coats. Been over 6 months now and no scratches.
Legacy Supercharged Tms Member
First, wet sand with 600 grit paper; then spray on about 3 coats of clear plastic primer and finally, within 3 to 10 minutes of your last coat of primer, spray on the initial coat of paint. I used three coats each of plastic primer and paint.
--John
Hey Redfire where did you get your silver trim that goes around your door panel?
http://www.mrmikes.com/trimbright.htm
--John
