Replacing door subs...(Again!)
Old Jun 20, 2006 | 05:13 PM
razorbackhogs's Avatar
Question Replacing door subs...(Again!)
I just have a quick question. Do the Polk/MOMO MM2084's fit in the doors? It is only 3/8 inch deeper than the RF Stage 2's . I am aware that some cutting is needed, but is it too deep to fit in the doors at all? (Yes, I will get a new amp (x2) as well)
The specs look stout for only an 8 inch sub.
Old Jun 20, 2006 | 06:36 PM
Infinity's Avatar
If you're willing to cut the back out of your enclosure, then yes, they'll fit. They're also nice little woofers. If you're going to hack, though, go with a Crystal CMP8 or an Ascendant Audio Assassin 8 or even a SoundSplinter RLi-8. Beastly little ****ers that will negate the need for any rear subs.
Old Jun 20, 2006 | 08:29 PM
Thanks Infinity for the reply...
I'll look into them!
Old Jun 20, 2006 | 08:48 PM
Hey Infinity, there is a great deal going on until June 23rd for the Assassin 8....45 bucks each!! What is the frequency response I should expect from these?
What amplifier would you suggest for these 2 subs?
Old Jun 21, 2006 | 05:11 PM
Infinity's Avatar
They'll take 450-500 RMS despit the ratings, so basically feed them whatever you can afford. Something like the Directed 750D would be in the sweet range for decent money. If you want to keep stereo separation , it'll take one hellacious stereo class A/B amplifier, or a decent size 4-channel bridged. Something like http://www.ubid.com/Kicker_KX650.4_650W_4_Channel_Car_Audio_Amplifier_ 04'_Series/a10700436-rsearchall.html
Be warned, that Kicker amp is HUGE.
Old Jun 21, 2006 | 07:21 PM
#6Fan's Avatar
RF Punch Stage 2
Here is the final RF look. With the factory sub they sound ok. would do better with an amp.
Attached Thumbnails Replacing door subs...(Again!)-punch-s-2a.jpg   Replacing door subs...(Again!)-punch-s-2b.jpg
Old Jun 22, 2006 | 07:30 PM
Infinity's Avatar
Those match up to the IUP semi-decent. Not bad, but I HAVE to have grills on mine, whether factory or not. I hit them with my foot every time I exit the car.
Old Jun 22, 2006 | 11:08 PM
RedDragon777's Avatar
now i did find 8" diameter sub with 3.75" mounting depth compared to the RF punch which is 4.06" depth and SoundSplinter's 5.60" depth...but will the 8" diameter fit and how much cutting would i need for the depth
Old Jun 27, 2006 | 12:58 AM
knucklehead_11's Avatar
I was looking into possibly buying those. Any issues with install?
Old Jun 27, 2006 | 09:28 AM
#6Fan's Avatar
You have to do some trimming on the back side of the door panel (nothing a little fiberglass can't fix and you also need an aftermarket sub to make it hit harder. Which I do not have...
Old Jun 27, 2006 | 10:56 AM
nbk13nw's Avatar
No trimming was needed with my install of the RF 8's. I did use a heat gun to soften and then mold the enclosure to fit.
Old Jun 27, 2006 | 12:50 PM
U mean aftermarket amp to make it hit harder... I gotcha... thanks!
Old Jun 27, 2006 | 01:44 PM
#6Fan's Avatar
yep amp..sorry
Old Jun 27, 2006 | 02:51 PM
yep amp..sorry
oh yeah i meant to ask... i'm assuming u got the 4 ohm subs but were they 4 ohm or 8 ohm?
Old Jun 27, 2006 | 10:12 PM
Okay...here are some more noob questions...
Alright, let's say I purchase a pair of 8" SVC 4-ohm subwoofers rated at 200W RMS.
If I want to put on a 2 ohm load, would I want 400 watts RMS x 1 at 2-ohms , with 200W RMS going to each speaker?
I guess what I am asking is, what is the best match for a pair of 8" SVC 4-ohm subs each rated at 200 watts RMS? (either RF S2 or MM2084)
Would this be the maximum RMS rating that it could handle?
Old Jul 1, 2006 | 08:35 AM
BatNastard's Avatar
Yep, the power would be fine (even more would probably be OK), just make sure you cross low (<150Hz). Also, you would probably need a class D amp, since most class A/B amps won't handle 2 ohms mono in bridge mode.
Old Jul 2, 2006 | 12:31 AM
Okay this electronics talk is giving me a headache. lol
Old Jul 2, 2006 | 08:14 AM
BatNastard's Avatar
LOL that's what beer is for!
I hear ya, eventually it becomes a constant migraine
Old Jul 2, 2006 | 10:31 AM
Infinity's Avatar
LOL, you got PM, bro.
Old Jul 2, 2006 | 12:13 PM
If only I could have one right now, lol.
