Rearview Mirror
Old Feb 6, 2007 | 10:39 AM
another 06gt's Avatar
Question Rearview Mirror
Has anyone updated there mirror. I would like to get the one with temp and compass. I felt the headliner and there is a slot for wire or some kind of plug.
Old Feb 6, 2007 | 10:57 AM
05RedGT's Avatar
Do a search - there are a couple of threads about replacing the mirror. YOu have to run a wire down the A-pillar to the fuse box. I am getting ready to buy one as well.
Old Feb 6, 2007 | 12:00 PM
mrkabc's Avatar
You'll need to pull the headliner trim panel and A pillar cover on the passenger side to run wires. The temp sensor will require you to pass a wire through the firewall (I put mine through the radio antenna grommet) and clip to the front of the radiator shroud.
I *highly* recommend using two "add-a-circuit" fuse box taps from Kragen (or some other auto parts store) for your switched and constant power wires. They tap in to your fuse block in the passenger kick panel.
Run a search for mirrors, I took a bunch of pics and posted them here, including which fuse #'s to tap in to and where to mount the sensor.
It sounds like a hassle but it really isn't that bad at all... I spent more time trying to get the OLD mirror off the car then running wires. It's a great mod!
Old Feb 6, 2007 | 01:33 PM
Thanks Art,
Old Feb 6, 2007 | 01:35 PM
Thanks Art
Do you have an idea or remember how much the mirror cost. I have to do a serch on ebay later. Did i hear you right the fuse box is on the passenger side. I haven't checked yet
thanks again Saverio
Old Feb 6, 2007 | 03:02 PM
mrkabc's Avatar
Hi Saverio:
I got my mirror/temp/homelink from here:
http://www.sportsimportsltd.com/hocoteaudilc.html
It's a company called Sports Imports LTD. I got part Part #50-GENK50 $349.00.
A bit more expensive than back in November 2005 when I bought the mirror (I paid $329). They shipped right away and I had no problems with this vendor. I even bought another mirror off them later on as a gift and it arrived on time and in perfect condition.
Yes, the fuse panel is in the passenger kick panel, it's easily accessible to install the fuse taps.
Good luck! I hope this helps. Have a good one!
A.
Old Feb 6, 2007 | 06:26 PM
mikes rx's Avatar
Do a search on ebay for gentex mirrors. Most of the sellers have storefronts, and some at really good deals.
Also, you can buy one off another vehicle, and install it, assuming it comes with the temp sensor (or, you can always buy the temp sensor after).
I installed a new Homelink dimming mirror (no compass/no temp)in my 05. But, in my 00, I installed a simple dimming mirror only (no compass/no temp/no homelink) from a 2000 Blazer, and it worked perfectly. Just make sure it comes with the harness.
Old Feb 7, 2007 | 04:34 AM
Thanks Mike,
Wow did you upgrade the ride.
Saverio
Old Feb 7, 2007 | 05:20 AM
mikes rx's Avatar
Thanks Mike,
Saverio
Old Feb 9, 2007 | 10:27 AM
did the search on ebay for the mirror. they have buy it nows from 199. I guess something else to save up for.
Old Feb 9, 2007 | 02:07 PM
mikes rx's Avatar
Yeah, this forum will help you find many things to spend money on.
Fedupdave42169
Oct 23, 2015 09:58 AM
MRGTX
Sep 16, 2015 08:08 AM
Earlsays
Sep 12, 2015 06:29 PM
