Radar Detectors
at the time I got a good deal on mine from Amazon.com I had a coupon for 20% off anything. So it made it the best deal. Just have to shop around my friend. I have the blue one also I figured the glare from the red one would hurt my eyes on long drives or be distracting at night.
I use the V1, have for years. On the 05 I used a fused add a circuit in the junction panel in the passenger kick panel to hardwire the connection. Ran the RJ-11 (phone cable) up, inside the pillar cover. Then I ran the cable under the headliner (following the map light wires) and exit the front of the headliner (near windshield) and to the radar detector. Mounted high on the windshield it can still pick up radar from all angles.
Originally Posted by Kahdir
Cobra Electronics XRS 9930 12 Band Radar/Laser Detector... works great w/ exception on arial?!? -Fighting that later this month
Got it from work
Got it from work
Got it from work
Got it from work
Originally Posted by mustangkid18
I use the same one but I don't think it picks up laser. Drove past a cop with his gun out and the darn thing didn't beep or do anything. Good thing I was only going 7 over.
It's supposed to... haven't had a situation to test it yet (*knock-on-wood*) -check to make sure all alerts are on; by default only 2 are on.
Originally Posted by karman
Our airplanes use distance marks in the breakdown lane to calculate speed. If you slow way down in between the marks they can't prove your speed. You can use a radio (scanner) tuned to their frequency to tell what area they are in.
