Power from Fusebox?
Old May 17, 2007 | 10:56 AM
GT98's Avatar
Power from Fusebox?
I have a Sirius receiver in my car, powered by the power point in the middle of the dash. I've been wanting to hardware to that, but I don't feel like tearing out the center console to do so...so I figured that I could wire it up to the Fusebox, but I don't have a clue as to where to start. Has anyone else done this or point me in the right direction? I have a nice MGW billet lighter plug I haven't been able to use because of this
Old May 17, 2007 | 03:59 PM
MTAS's Avatar
Looking for 12v switched ign. circuit - ModularFords.com
Old May 17, 2007 | 07:47 PM
Got Oatz's Avatar
Just pick up an Add-A-Circuit at the local auto parts store....Pic below...I wired my Raptor with one. I used fuse spot 14, as it is switched, and has room below it for the Add-A-Circuit. Note the pic below IS NOT plugged into slot number 14, but you get the idea. Check you manual for the fuse number locations...
Mike
Old May 19, 2007 | 08:55 PM
pony power's Avatar
I Wired Mine To The Radio Fuse. Just Snipped The Lighter Plug Off And Slipped The Hot End Under One Side Of The Fuse So It Was Pinched In The Metal Clip. Evry Time I Drive The Car The Sirius Tuner Is On And When I Turn The Key Off And Open The Door Oit Goes Off Just Like The Radio. Cost Me Nothing To Do It And Took About 5 Minutes To Get It Done
Old May 20, 2007 | 12:56 AM
RedDragon777's Avatar
here is a better pic of the fuse box and all i did was drill a groove on the bottom of the fuse box cover so it would not pinch and i could still use it
Old May 20, 2007 | 12:57 AM
A and C obviously are switched (turns one and off with the car) 12v sources and B is just a constant 12V source
Old May 20, 2007 | 12:59 AM
oh and when you get it done please post up a write up because i bought a cigarette extension so i would not have to cut into the factory sirius plug and i want to make the extension a constant source
Rando
Aug 25, 2021 11:12 AM
RCooke08GT
Feb 19, 2017 03:03 AM
Fedupdave42169
Oct 23, 2015 09:58 AM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
