OD Shift button repair...
Old May 13, 2008 | 09:24 AM
watchdevil's Avatar
Hey everyone I wonder if any of you know how to remove the OD shift button from the RH side of the auto shifter if it is possible. During reinstallation of my shifter the twin wires that run up the middle of the lever got pinched in half way up inside the inner part and I wanted to salvage operation of the OD button by repairing the wires from the backof the button. I cannot figure out how the button can be removed without damage. I was hoping the RH lever barrel would just snap off the end but I cannot get it to come off.
At the worst I suppose I will just have to replace the entire shift lever.
Old May 13, 2008 | 10:07 AM
kingofsting's Avatar
Theres a screw on the back of the handle (Facing the hvac) that holds the thing together. Using a small phillips, unscrew it, and gently pull the handle off the rod. the handle can then be pulled in half (gently!) and the OD button will become dislodged
Old May 14, 2008 | 12:25 PM
watchdevil's Avatar
I already know how to remove the entire lever by removing the torx screw on the back of teh shifter and sliding it off the shifter shaft. What I want to do is take the OD button off the RH of the handle. I have tried taking it off and I dont see how to do it without marring or breaking it. There is no screw that holds the shifter together. I assume the black barrels snap into place on both sides of the bright shifter and is really not meant to be removed.
jim010
Jun 24, 2024 04:23 PM
Gigantor
May 11, 2023 07:31 PM
K.A.I.N
Sep 25, 2015 03:27 PM
jim010
Sep 7, 2015 02:40 PM
