Nexus Gauge install
Old Nov 5, 2006 | 05:36 PM
Torch_Vert's Avatar
Nexus Gauge install
I just added a set of Autometer Nexus gauges to keep an eye on my supercharger install. I put in a boost/Vac and fuel pressure gauge, along with the control module and remote.
I went with the Nexus gauges to keep things in line with the factory My Color dash in my car (like the factory dash, the nexus gauges can change color, and will highlight a gauge showing a danger reading in red (or blue if the gauges are already red)
The system can also recall and display peak readings on the gauges, and data log onto a flash card for PC analysis.
The gauge pods are from Speed of Sound (www.speedofsoundllc.com) and have a perfect finish. They look like they came with the car.
The shift light atop the bottom pod is from Raptor Performance (http://www.raptorperformance.com/) It's a very nifty little device. Easy to install. Functions perfectly, and looks really nice (the angle in these photos don't do it justice)
Old Nov 5, 2006 | 07:16 PM
Greywolf's Avatar
Very Very nice.
Old Nov 6, 2006 | 10:52 PM
Mongoose's Avatar
GREAT I like it. Problem is no A/F Nexus
Old Nov 7, 2006 | 03:56 AM
hawgman's Avatar
You installed too soon. Alan is about to release a 3 gauge pod setup. He is already taking preorders.
Old Nov 7, 2006 | 12:52 PM
S197 GT's Avatar
3rd Times A Charm
I was about to say the same thing....
I have the NEXUS gauges too and love 'em!
Old Nov 14, 2006 | 01:46 PM
tmf's Avatar
tmf
+1. I have 5 Nexus gauges in my Marauder and was waiting for the A/F gauge which is supposed to be ready any time now.
Looks like I'll be getting them for the GT/CS now too.
John
Old Nov 14, 2006 | 03:03 PM
Torch_Vert's Avatar
No, I didn't. I like the looks of the 2 gauge pod much better. It looks cleaner and less cluttered to me.
If I install additional gauges, I'll try to get something like the Saleen pod for the dash top.
Old Nov 19, 2006 | 11:19 PM
mikeelia's Avatar
Very cool. They are infinitely adjustable to match the IUP color?
Mike E
Old Nov 20, 2006 | 04:54 AM
Torch_Vert's Avatar
Mike E
Not "infinitely". They have standard colors that match the MyColor presets, but the control module doesn't have a feature to create your own custom color, though the gauges themselves are capable of it.
There is some programming software promised by Autometer that may have that ability.
Old Aug 10, 2010 | 09:38 PM
kaponelb's Avatar
I had a question I just got the nexus gauges also but wanted to know if u can show me how u hooked up your fuel pressure gauge I also have a x charger can u show me pics on u installed it
Old Aug 12, 2010 | 12:42 AM
Torch_Vert's Avatar
I don't have good pics of the area where the sender is installed, but basically, I got a fuel rail adapter for a GT (fits the 4.0 rail too) similar to this one (I don't remember what brand mine is): http://www.hillbankmotorsports.com/2...2005-2010.html and mounted it to the driver's side fuel rail, under the existing pressure sensor, and just threaded the Nexus sensor right in.
Old Aug 12, 2010 | 09:25 AM
kaponelb's Avatar
Ok thank you going to go pick up the adapter today so to install that one do I take the one that came with the xcharger and replace it with that one did you use any Teflon tape to prevent leaks thanks for the help
Old Sep 13, 2010 | 03:20 PM
bigray327's Avatar
Here are mine. Love em.
Old Sep 20, 2010 | 05:46 AM
Scott2's Avatar
I installed the fuel pressure sender on my Fore Percision Fuel Rail.
Old Sep 20, 2010 | 05:51 AM
Scott2's Avatar
+1 Love em too!
Old Sep 20, 2010 | 11:24 AM
Scruffy281's Avatar
Where are you guys getting the Constant and Switched 12v for the control units?
Old Oct 10, 2010 | 11:50 AM
Scott2's Avatar
Power is taken from the passenger’s side fuse box. “B” for constant power. Do not use “A” for switched power. The “Add-a-fuse” tap that that I was using did not work in “C” so I ended up using the fuse right below “C”. Hope this helps.
Old Oct 11, 2010 | 11:31 AM
MLC40's Avatar
What is wrong with using A for switched power? I think I have mine there.
Mr. V
Dec 24, 2016 02:57 PM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
