Need Help With '07 Dimmer Wire
Old May 20, 2008 | 02:18 PM
JayFi's Avatar
Ok - so this morning I started installing my Pioneer head unit and XM tuner. Everything went fine until it came to the dimmer wire. I had read this thread which says you can tap a blue/yellow wire off of the hazzard light harness:
http://forums.bradbarnett.net/showth...ht=dimmer+wire
Problem is, I don't see a blue/yellow wire! I tried a blue/light orange wire thinking that it might be it, but it doesn't do anything. Is it possible the wire color changed on the '07's?
Here's some pics of the harness that I snapped with my cell phone (sorry the quality isn't the best, but I figured it might help)...
Attached Thumbnails Need Help With '07 Dimmer Wire-img00133.jpg   Need Help With '07 Dimmer Wire-img00134.jpg   Need Help With '07 Dimmer Wire-img00135.jpg   Need Help With '07 Dimmer Wire-img00136.jpg
Old Jun 3, 2008 | 05:34 PM
Well I finally completed the corrected dimmer wire install on the new deck. I used the yellow with white stripe wire that attaches to the back of the info/setup/reset buttons to the left of the power outlet above the radio. This wire evidently sends power to LED's on these buttons.
So once and for all splice into the yellow with white stripe wire behind the info/setup/reset buttons on the center stack. You will splice in with the illumination wire from your aftermarket harness or new deck.
Hope this helps everyone.
Old Jul 27, 2008 | 10:14 PM
frdtch05gt's Avatar
That actually helps me out a lot. I need to hook up the dimmer wire for my Power Acoustik nav/dvd unit. I have an '06 and didn't have a blue/yellow wire anywhere. I'll look for the yellow/white wire, it should be there.
May 3, 2026 05:42 AM
RCooke08GT
Feb 19, 2017 03:03 AM
Fedupdave42169
Oct 23, 2015 09:58 AM
mx5jhb
Sep 30, 2015 04:44 PM
Sep 23, 2015 03:21 PM
