My floor heat fix
Old Oct 27, 2008 | 07:14 AM
My floor heat fix
I don't like the way the floor heat kicks out. It doesn't seem to warm my feet well enough. So here is my 10 cent fix.
I cut the corner out of a case used for beer or pop. The kind that holds 4 6 packs.
I used some 2 sided tape on the inside
and then attached it to the heat duct on the drivers side.
The heat now blows right on my feet. Werks for me!! Its not real pretty but no one will ever see it where it is mounted.
Old Oct 27, 2008 | 11:30 AM
n8rfastback's Avatar
thats a pretty good idea.....
Old Oct 27, 2008 | 01:18 PM
Superfly SN95's Avatar
Very creative
Old Oct 27, 2008 | 01:38 PM
LEO_06GT's Avatar
Foot heater? We don't use that here in SoCal unless it gets under 65.
Old Oct 27, 2008 | 02:02 PM
Blue is our choice of color
Old Oct 27, 2008 | 03:44 PM
lol werks for the air conditioner also I guess. I need to visit Ca. some day.
Old Oct 28, 2008 | 08:07 PM
Shotokan1509's Avatar
Ha, not a bad idea... but what I really want is a way to divert the heat directly to the shifter. I tend to drive with the windows down 95% of the time, even with it in the 30's on my drive to work. I can get the left vent on my steering wheel hand, but the right hand gets cold.
Old Oct 29, 2008 | 07:03 AM
here ya go attach a piece of this to your vent and run it where ever you want lol
Old Oct 29, 2008 | 07:34 AM
Indystang's Avatar
Half my floor heat come up through the defroster vent. It comes out at the feet ok just not enough comes out.
Old Oct 29, 2008 | 08:45 AM
I was actually thinking of something like that on my drive into work.. but instead of being on the front of the vent, actually mount it inside the vent so I can pull the vent out to direct it down, but also slide it back in to look stock.
Old Oct 29, 2008 | 09:25 PM
houtex's Avatar
"Its not real pretty but no one will ever see it where it is mounted."
Um... I see it. It's right there, man.
Actually, using that as a template, you can get some sturdy plastic, prime and paint it bumper black, and stick it in there... then it'll look more stock.
That's what I did for Muskrat around the gas fill... made template outta thin cardboard.. then used that on some *thick* cardboard, and carpeted it, and screwed it in place.
Looked kinda stock when I was done with it...
Dang I miss that car...
Old Oct 31, 2008 | 12:26 PM
Error404's Avatar
I get complimentary heat coming up from the shift column Maybe some baffles or something were left out when my transmission was swapped out, but either way, after a while of running I can feel warmth coming up from the shifter area. My old camaro used to do this too.
Old Oct 31, 2008 | 07:58 PM
Stoenr's Avatar
Lol, thats too funny. I think mine does a good job. I use the floor vent more than anything, unless a hot summer day.
Old Oct 31, 2008 | 08:06 PM
GottaHaveIt's Avatar
Dude you have a patent on that ? well you had better hurry before you get beat a sued for stealing someones idea ! lol good thought thanks for sharing the tip.
Old Oct 31, 2008 | 08:07 PM
tom281's Avatar
Good idea Glenn........ midwest ingenuity!
Originally Posted by Glenn
lol........... I need to visit Ca. some day.
Nah, it's over-rated.....
Old Oct 31, 2008 | 08:11 PM
wjones14's Avatar
That's hilarious! But whatever works for you, man! The car does eventually warm up, but this is the first car I've ever had where you can't feel the heat coming from the floor ducts. I usually set the control to send heat to the vents and floor until I am totally warmed up, then direct the heat to the floor to maintain the temperature. It is a crappy design, however, so I don't blame you for doing what you did.
Old Nov 1, 2008 | 12:16 AM
You're just jealous because I can drive my car everyday
Old Nov 19, 2009 | 06:37 PM
tried to update the pics to no avail, I couldn't delete the new post
Old Nov 21, 2009 | 10:24 AM
or this with flex tube ?
Old Nov 21, 2009 | 10:39 AM
Sweet defrost setup there.
