Machinist / Machining Question
Old Jun 26, 2006 | 10:38 AM
mail906's Avatar
I'm working on a shift **** adapter.
My question is this. If I buy an aftermarket shift **** adapter that is essentially an aluminum cylinder threaded to screw onto a 10 mm x 1.25 shaft, is there enough material there to thread it; or drill and thread it to fit a 12 mm x 1.25 shaft?
It has been suggested to me that the Ford stock 5 spd shaft is 12 mm x 1.25. Am I correct on this?
Does anyone know a vendor who sells a shift **** adapter like this; or can make one for me?
Hope I am not a nuisance. Thanks for your continuing help. W.
Old Jun 26, 2006 | 11:49 AM
shaun_beauchamp's Avatar
Dear Walt,
10mm to 12mm is 2mm and that is total diameter. Machining would give you TOPS 1mm per side (.039 in), which if made out of any ordinary materials will not give you significant strength.
Post an image of what you're trying to do and I will see what options are available as a "fix".
Old Jun 26, 2006 | 11:23 PM
Mongoose's Avatar
Less than that when you figure in the thread depth of the male 12mm. Do not think I would want to make this for someone other than myself. Wax up the shifter shaft with paste wax and stuff JB Weld in the ball and set it on the shaft. Works every time. Make sure you wax the shaft or it will be on there for a lifetime.
Old Jun 27, 2006 | 05:49 PM
http://www.pelicanparts.com/BMW/tech...Momo_shift.htm
Dear Walt,
Based on the Momo shifter you want to use, it appears that Momo supplies some rubber "tubes"/ spacers that take up the gap between the shaft thread and the **** itself. This will give an interference fit between the **** and shaft which ideally secures the ****. Then there are 3 setscrews to keep the **** from coming up off of the shaft. From there a lower threaded portion covers the setscrews for a clean look. Momo seems to have worked this one out, but if you want a cylinder machined that fits over the shaft threads and has an O.D. of 15mm I'm still more than willing to assist you.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
