Kenwood DDX-7017 Install Complete
a little off topic but a Kenwood DDX-7017 nonetheless...
I installed mine about a year ago (thanks to Hawgman and others) and every now and then the Kenwood DDX-7017 has trouble ejecting a DVD disc. I have to stick a credit card in the slot to get it out.
Anyone else having this kind of problem?
i just have to say that that is an awesome place for the camera... i was reading that you had the rear cam.. then i was thinking to myself- where could he have put it where it didn't look like A$$.. then i scrolled down and i was like its just the gt embl.. wait- theres the camera! awesome.... so- i just felt like saying that it was cool
![Banana](https://themustangsource.com/forums/images/smilies/banana.gif)
Here are a couple of the U shaped bracket I made from an old license plate.
Attachment 19790
Attachment 19791
Here is the camera mounted in the hole for the lock. I took off the camera cap and inserted the camera in the hole and put the cap on from the outside of the hole. I put some silicone between them to help with sealing. I also had to get an O-ring to go inside the cap to keep the clear lense in place since there was a gap because of the thickness of the trunk.
Attachment 19792
Here is the camera with the U shaped bracket.
Attachment 19793
Attachment 19794
i love this setup!
i have a Garmin StreetPilot 2820 mounted on the center of my dash, and the shaker 500, with a rockford fosgate amp and punch stage 3 sub in the trunk..
i'm missing an equalizer with the shaker, and the StreetPilot is taking up much space on the dash, where i could otherwise out up a shelby style gauge pod for my upcoming SC.
in any case, your setup grabbed my attention due to the mere fact that the navigation unit runs Garmin Software!
does that mean you can use Garmin's mapsource and POI Loader (to load custom POIs like speed cameras and the like)?
if so.. how do you hook it up to your PC to update the maps?
does it get the maps off Garmin's City Navigator DVDs?
i love this setup!
http://www.kenwoodusa.com/support/si...px?men=2&M2=69
Question comes to mind 1SG.
Did the harness you used have RCA plugs on one side, or you had to cut and splice that to wire it to the new head unit?
furthermore, could you please elaborate how you hooked up the factory speakers, amps and door subs?
any additional adapters, etc?
i'd appreciate a fast response, as i'm hoping i could get the needed stuff and work on this over the weekend (which in my case is Friday/Saturday)
i'd appreciate a fast response, as i'm hoping i could get the needed stuff and work on this over the weekend (which in my case is Friday/Saturday)![Smile](https://themustangsource.com/forums/images/smilies/smile.gif)
This will power your subs. Connect the white RCA plug with a Y splitter to the Red and white rca plugs coming from the HU labeled Sub Woofer. The speaker wires on the metra harness are all marked as are the speaker wires on the HU. Just match them up and your good to go.
Hope this helps,
Kirby
It COULD theoretically blow the door subs due to over excursion (the voice coil jumping out of the gap), but I've never seen any proof of that happening. I ran mine with the pop for about 3 months until I put my Aura amps on the doors. A LOT of difference, but they still need more power. I'm giving them a true 60rms, I'll try 100 when the weather warms enough for me to change things.
One thing I like about it in addition to being able to put 4GB's worth of MP3's on a DVD you can also put some JPEG's on it and play a slide show or pause it on one picture and display it while you listen to the radio or sirius.
Attachment 18723
Attachment 18723
the interface was ugly!
the user interface was a grainy green, blue and purple.. kinda like running windows 95 without display drivers, on 16 colors :S
i was seriously let down by the display.. although it was pretty crisp and clear with the nav module plugged in, or even while playing a DVD.. making me believe that it's the software itself that was crap.
finally, i put on some music, and couldn't for the life of me figure out how to get spectrum/equalizer bars.. all i had was a solid blue display with a few purple/green soft keys.
i love the unit's features and sound quality.. i just hate how the interface looks!
what do you think about it having had it for sometime now?
#40
I pretty much just leave the Nav screen on all the time while I'm listening to Sirius. I agree with you about the interface but I'm not a big audiofile so as long as it sounds decent I'm ok. I think is does sound much better than the Shaker 500.
