K&N Check Engine Light
Old Feb 4, 2011 | 07:26 PM
mchief_k2's Avatar
I installed a K&N CAI (63-2565) back in December on my 08 GT. The reason why I picked this set is because I didn't want to mess around with tuning it.
So far, I had the check engine light come on twice in as many months. I know the first time, I was really stepping on it and second time was driving around town.
Each time, I disconnected the negative terminal and light went off. This is a real pain the rear and was wondering if anyone else had the same issue and what can be done about it.
Thanks.
Old Feb 11, 2011 | 06:23 AM
07vistavert's Avatar
I've had the 57-2565 for 4 1/2 years and have never had the light come on. However, I run 93 octane as insurance just in case the "no tune" approach leaves it a little lean.
Old Feb 11, 2011 | 04:57 PM
shooterm1's Avatar
It may not even be directly related to the K&N ...
have you checked the codes?
Old Feb 11, 2011 | 08:42 PM
mchief_k2's Avatar
Thanks for the suggestion. No, if it happens again, I think I will have to do exactly that.
Old Feb 12, 2011 | 06:10 AM
Everett's Avatar
Get tuned for it or its a waste of money for no gain
Old Jan 23, 2012 | 05:47 PM
mchief_k2's Avatar
Talk about resurrecting an old thread! Anyways, after about a half dozen times of resetting the check engine light by disconnecting the battery, finally made the trip to auto zone to get a reading. Best part it did not cost me a dime. Turns out that code was p0174, which one common cause could be dirty MAF. Look at http://www.obd-codes.com/p0174 to see if this applies to you. These filters are coated with oil and that may be a cause. My car runs better and all I did was to buy a can of CRC MAF cleaner, took me about 10 minutes. It's been a few days and no light but only time will tell.
Ecostang
Nov 3, 2022 08:50 PM
STOERKEL
Sep 11, 2015 11:38 AM
ClayP
Aug 11, 2015 06:23 AM
Will3212
Jul 16, 2015 10:30 AM
