IPOD / PIE Installation Issues on 2006 GT
I know there are many forums out there on the IPOD but I wanted to let you know about my install on my 2006 GT. Hopefuly it will help others (or maybe not)
1) On one of the forums are posted instructions how to remove the stereo (These look like Ford instructions, whoever posted them, thanks). These are brilliant instructions but are slightly flawed for the 2006.
2) Following the instructions there is no way to remove the consol. I tried everything but no luck. In fact you don't have to remove it to install the adapter or get to the stereo.
3) When removing the center panel finsh plate the instructions say to disconnect the wiring at the top of panel. In fact there are 2 connectors at the bottom also and no way will the one on the right come off. Some sort of special plug which I could'nt fathom how to do.
4) The stereo won't actually come out as Ford have taped the wiring harness to the frame at the back of the stereo. You need to cut the tape on the harness to get any sort of flexibility.
5) The PIE adpater only gives output from the IPOD and does NOT allow the IPOD to be controlled from the stereo (SHAKER 500). I thought it did.
6) Once fully connected the system didn't recognise the IPOD so I called PIE and Victor advised a bug in the system whereby if you reconnect the Ford harness (with the 2 wires) into the PIE harness, it doesn't register. Disconecting the Ford harness solved the problem but now there is no speed/volume function or light dimming function on the stereo. Victor has a Beta chip in test he will send so I can try. I'll let you know how it goes.
7) Finally, getting the consol finish plate back on was a problem and I ended up scratching the top of the parking brake. Now I need to clean this up to remove the hideous scratches.
I'm not going to go point-by-point, but I can answer some of these concerns.
The known bug with the PIE adaptor exists on the 2005 as well, and they are currently beta-testing a chip which fixes it. Elsewhere on the forum (too lazy to find it, search for PIE or something) you'll find that someone has received the beta chip and it now works great with both cables installed. There is no ETA on when the fix will go public though... perhaps they don't want another oops.
As for controlling the iPod from the radio, you are correct, there is no way to do that with this PIE adaptor. On the two places I have found descriptions of the adaptor, they did tell you this, though they certainly didn't make it clear. A lot of the other PIE products DO allow you to control the iPod from the radio, but perhaps the Shaker doesn't allow that interface. All I can say is that hopefully you can find a convenient way to mount the iPod so that you can mess with it while driving and not run into a semi
I have not done an install, so I can't speak about taking apart your dash, but it's possible they've tweaked some of that for the '06, which could cause the instructions to be somewhat inaccurate. Has anyone got the shop manuals for the '06 that can say if they're different?
Where did you purchase the adaptor? I know that logjam said that they would replace the chip on the PIE with the updated software once it is released, and hopefully any other place would do the same. If not, you might try returning it as defective (it is!) and get one once the fix is established and publicly available.
I had no problems at all putting it in or making it work with all the wires attached. The hardest thing I had to do was figure out where I wanted the module.
[I do not have an iPod, I just connected it to my laptop hence I was not expecting any control at all.]
That connector you mention as "no way it will ever come off" was infact quite easy to remove on my 2006. It has a little clip/lever around it that you need to push up. Once you do that it will pop right out. Its the connector on the right side. The one on the left just pops straight off but for me it was on very tight. I found the center console and radio removal to be very easy. The hardest for me was the rear speaker deck installs due to the limited space at the window.
Sorry, I don't remember what colors they were. Only that it was the bottom right connector when looking at it headon from drivers seat. To remove it just go over to the passenger side and use a flashlight to get a better view. I only remember the clip being pushed up which allowed the connector to come straight out.
Ok, latest update:
Installed the latest chip from PIE and hey presto, the stereo now dims with the rest of the dash lights.
Finally managed to get the troublesome plug off the back of the dash plate with a little force, now it comes off no problem.
Note to others: No need to remove any centre consol items to remove the stereo. You only need to remove the bezel and loosen the consol cover but that's it.
Hope this helps anyone doing this.
I still haven't received one of the new ones. I was like the 9th person to buy one from logjamelectronics.com. I selected the option to get a new on their website and haven't received it yet. Has anyone else got their new replacement one?
mustanglindsey
Feb 15, 2026 04:48 AM
Mustang259
'10-14 Interior and Audio
74
Mar 25, 2016 04:27 PM
tdf017
Aug 5, 2015 10:13 AM
