Installing Gentex Mirror
Old Jun 13, 2007 | 04:12 PM
jim010's Avatar
I bought the Gentex mirror with temperature and compass (No homelink) and I am trying to figure out how to install it. The pigtail that plugs into the mirror has 7 wires, and I don't know what they are all for.
Anyone able to help?
Cheers
Old Jun 14, 2007 | 12:51 PM
mrkabc's Avatar
Cheers
Wait until I get home, I will scan my instruction manual and post it here for you. It covers ALL Gentex mirror installations.
Old Jun 14, 2007 | 02:07 PM
jim010's Avatar
Cheers
Old Jun 14, 2007 | 07:39 PM
mrkabc's Avatar
I made a scan of the complete instruction manual for ALL Gentex mirrors, including wiring diagram and programming instructions.
It's in Adobe Acrobat PDF format. Unfortunately, this site won't let me upload the document. I have spent the last 1/2 hour trying, it says "upload failed". It's a 2.4 MB document.
PM me your email addy and I'll send it to you.
A.
PS:
In the meantime, here is what the manual has to say about the wiring:
BLACK: Ground Wire
RED: +12v switched power (ignition switch)
GREEN: Temp probe wires (compass/temp mirrors only, no polarity specified)
YELLOW: +12v constant power (map light model only)
BROWN: Dome light circuit (map light model only)
Hope this helps!
Old Jun 14, 2007 | 08:44 PM
2MFF's Avatar
Try this link
http://www.aaaremotes.com/homelinkmirrorinst.html
Old Jun 15, 2007 | 10:06 AM
jim010's Avatar
Well...
The wires I have don't match up with what you posted. In order I have:
whitish pink
black
green
grey
white
green w/ black stripe
brown
Help?
Cheers
Old Jun 15, 2007 | 02:15 PM
mike3000's Avatar
I think my memory is coming back to me. Mine also had more wires than needed, but I only used what the instructions stated. For example, one wire was for a backing-up (used to turn off auto dim in reverse). I used a total of 4 wires. Did you get instructions which stated which wires to use? If not I an probably email it.
Old Jun 15, 2007 | 03:55 PM
jim010's Avatar
My instructions do not tell me which wires to use - they are pretty vague.
Cheers
Old Jun 16, 2007 | 01:06 PM
mrkabc's Avatar
Check your email!
Old Jun 17, 2007 | 01:13 PM
jim010's Avatar
Thanks!!
Old Jun 18, 2007 | 02:27 PM
jim010's Avatar
The instructions still don't match up to the colours I have on the harness. Can you tell me which wire is for what going from left to right?
Cheers
Old Jun 18, 2007 | 04:13 PM
mrkabc's Avatar
I'll take a look after work and get back to ya!
Old Jun 19, 2007 | 10:27 AM
jim010's Avatar
Thanks.
I think I narrowed it down to the far left pin is hot - the one next to it is ground. The 2 far right pins are for the sensor. One of the middle 3 is to be connected tothe backup lights.
Cheers
MRGTX
Sep 16, 2015 08:08 AM
Earlsays
Sep 12, 2015 06:29 PM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
