Installed door sill inserts from American Muscle
So I ordered these the other day and just recently installed them...
http://www.americanmuscle.com/shblmudosiin.html
The reviews are pretty spot on. They don't fit at all. It's kind of pathetic really. Not one of the decals is even close to the letters on the door sill. They actually do look good if you're not really close to them, so I'll probably just leave them on. It's such a good idea, but how could they mess these things up so bad?
Former Vendor
In the mean time, shoot me a PM with your order number and I'll make sure you're credited back for this item. You can still keep them as well! Again, I apologize for the inconvenience this has caused you. I hope this helps!
-Dan
Thanks Dan. Don't get me wrong, I love your website and I buy a ton of stuff from you guys, just no clue how these things are so off? This is the only thing I've ever bought from American Muscle that wasn't perfect. You guys do have great customer service though, that's for sure.
I'm sorry to hear that these inserts didn't fit well. I wasn't aware that we had a problem with fitment on this particular item, I'll definitely have my product development and vinyl team look into this for me right away!
-Dan
That's odd, because it does fit. Many people put those rears on their car, even on v6s.
It fits an it on there but it's not perfect by any means there are multiple spots where it looked like the mold was off when it was made Im thinking that its my luck I got a bad one and on top of that the guy who painted it painted it the wrong version of vista blue so it doesn't match the car
Vista Blue is Vista Blue. Maybe he painted it Sonic Blue instead?
I've changed a lot of things on my car and everytime the shop wanted to test fit it before they did any paint work , so if there were any problems they could fix them before painting. If your shop didn't do this , then they're not very reputable and I wouldn't use them again.
There are two kinds of vista blue on has a flake that make it more purple than blue thats what the bumper is and the car is the one that doesn't have the flake
The factory paint code is on the door jamb sticker, maybe you should check. Your paint and body guy sure as hell should have.
If yours is not a metallic blue, it may have been repainted before you got it?
Not picking a fight here but I have only ever heard of one Vista Blue (G9) and it is metallic. That's what mine is. It is very sparkly.
It could even be the paint quality, improper air pressure, an improper reducer mix, an improper catalyst mix, they could have had the gun to close or to far away when they were spraying. All of these scenarios can easily chainge the color or how the metallics lay down when you are spraying them.
This is very true... but with the proper product knowledge, and knowing how to use your reducer and catalyst mixes... there should be no metallic or paint matching issues between painting on metal or any other surfaces that have been properly prepped and sprayed with the right primer.
I dinged mine after only 2 weeks (I did NOT see that tree in my yard ).
My right rear quarter-panel and rear bumper got resprayed. You cannot see any difference.
Of course the guys I used are the best in South Alabama.
