Inexpensive Interior Mod
Old Dec 11, 2006 | 10:09 AM
HOTLAP's Avatar
All, last night I added footwell courtesy lights to my '07 GT/CS vert. It is an inexpensive mod ($10 - 15$) and adds a nice touch to your interior that Ford really should have included on our Mustangs from the factory:
Materials: Qty 2 12 volt side marker light sockets, 2 12V wedge base bulbs wattage of your choice (I used 7 watt but you could use 4 watt, or 11 watt, etc - think your low voltage landscape bulbs here), 1 roll of 16 - 14 guage automotive wire, 6 plastic wire taps (red ones - 14 - 18 guage), electrical tape, optional split plastic flex tubing, several cold beverages of your choice and a good football game on the workshop tele
Directions:
1) Remove the passenger side "A Pillar" trim piece. It is attached by a compression clamp, and velcro (coupe may have 2 compression clamps and the vert you have to remove the 2 sunvisor screws). Pull the trim piece out then up (disengaging the windshield area tabs as you pull away from the dash)
2) Locate wire harness connector about 1/2 way up the A pillar. Pull the harness out and unwrap about 4 - 5 inches of the harness on the downside of the connector. Locate the BLACK w BLUE stripe wire and the GREEN w YELLOW (yellow) stripe wires.
3) Measure enough of the 16 guage wire to follow the existing harness down the A pillar behind the glove box area, under the center stack and over to the driver's footwell area. You will need two identical length wires and be sure to cut long as you can trim it later.
4) Run the wires down the existing harness (I used small zip ties to attach or you could use electrical tape), once you get behind the dash run the wires down behind the glove box (parallel with the orange antenna wire) and then look through the center stack below the radio (plenty of room for the wire to run through) then out to the driver's footwell area. At this point I went back and installed the plastic split flex tubing to protect the wires (mostly overkill) but you never know.
5) Find your desired location for the footwell courtesy bulbs - I used one of the heater core screws on the passenger side and zip tied the driver's side socket right under an exising wiring harness. Take your time here and get the bulbs positioned so they are pointing downwards and up enough so they are in danger of being kicked, etc.
6) Now back to the A pillar harness wiring procedure. Take your plastic wire taps and connect the first wire to the Black w/Blue wire and then connect the second wire to the Green w/yellow wire ( be sure you tap into the wires at least an inch between the taps so you don't chance the taps being too bunched up to fit under the A pillar trim piece).
7) Test the footwell lighting function and reinstall the A pillar trim piece.
You should now have footwell lighting that works the same as the overhead courtesy lamp circuit. On when you unlock/open the door, phase out the same as the overhead maps and switchable through the dash panel "on" switch - just like the overhead map lamps. Using this method - your individual map light switch functions will not be changed - they will still turn off/on independently of each other. This mod makes getting in and out of the Mustang nicer - especially with the black carpeting!
NOTE: Do not ground the bulbs/sockets - you are running two wires -one already acts as the ground and the courtesy dimming circuit will not work properly if you run just the black/blue OR green/yellow wires and ground the other wire.
Good Luck and enjoy this easy mod
Old Dec 11, 2006 | 10:12 AM
FLAstangx3's Avatar
....and the Pictures are....WHERE??????????????
Old Dec 11, 2006 | 10:46 AM
05fordgt's Avatar
Sounds like a really cool mod. If you can get some pictures to go with the excellent writeup, it would be terrific. Can't wait to see the pics.
Old Dec 11, 2006 | 11:00 AM
HOTLAP's Avatar
Sorry guys....I have not had very good luck with my digi camera / computer...get all kinds of errors when I try to upload pics....so I didn't take any...it really is a fairly straightforward mod though and well worth your time.
Old Dec 12, 2006 | 03:21 PM
SuperMach1's Avatar
sounds like a great mod, would like some pics though, try again haha, may try this weekend
Old Dec 12, 2006 | 07:23 PM
Dougxox's Avatar
Sorry, someone had to do it.
sounds like a great mod, will work on it, Thanks
Old Dec 12, 2006 | 10:08 PM
HOTLAP's Avatar
Hey Doug - that's cool and you guys are going to make me spend a Sat. fixing this darn glitch between my camera and computer....once you pull off the A piller trim piece - you'll see the wires and it's a cake walk from there...did I just type cake walk ...man I gotta go to bed
On the brighter side, I unlocked the Stang with the fob and the footwells lit up nicely - great balance to the kind of weak overhead map lights - well worth the effort!
Old Dec 12, 2006 | 10:17 PM
RedDragon777's Avatar
so i am just thinking do the same thing for the passenger side aswell right (even though it seems like a given)
Old Dec 13, 2006 | 07:54 AM
05fordgt's Avatar
Did you edit your photos, so they would fit? the pics have to be below 500 mb, if I am correct. Just shrink them down small enough to fit, save to your computer, and then add as attachments. Then they should work great.
Old Dec 14, 2006 | 07:35 PM
HOTLAP's Avatar
Ira - if I understand your question....yes, you do both footwells with this mod....you are actually running the wires down the A pillar and under the dash to the driver's side so you add one light to each side simply by tapping into the wires.
Old Dec 14, 2006 | 07:36 PM
HOTLAP's Avatar
Jeff, I wish it was that simple...when I try and download pic from my digi camera to the computer - it always gives me an error code and locks up....I probably need to reinstall the camera CD and start over again.....thanks though
Bryanh24
Oct 14, 2015 08:43 AM
