How to wire a trunk release button
Old May 5, 2005 | 11:59 AM
  #41
flamin ponyexpress's Avatar
Originally posted by icemant180@May 5, 2005, 12:15 AM
I don't understand the purpose of hiding the button. So how do you lock the rear seats? If a thief really wants or knows what you have in your trunk they will just punch out the trunk lock on the lid with one strike.
All you got to do is put the cloath pull handles toward the inside of the trunk and the only way to get the seats to come down would be from the inside of the trunk.
Old May 5, 2005 | 03:31 PM
  #42
dustindu4's Avatar
9 is not my lucky number.
huh?
Old May 5, 2005 | 11:07 PM
  #43
dustindu4's Avatar
Just a general update, I've started noticing that every time I close the glove box hard the trunk pops open. Oops. I guess I have to extend the little rubber stopper on the door so it won't hit the button.
Old May 19, 2005 | 08:14 PM
  #44
SoFlaBoss's Avatar
Hey Dustin,
Thanks to your fine instructions, I now have nice new trunk release button
And it even works too! I installed mine a little to the right of where you placed yours, thinking it might have a better chance of not popping the trunk when you close the lid hard. However, when you slam it a little too hard it still popped the trunk, like yours. The cure seems easy enough. The rubber stopper is hollow and caves in too easily, so I filled the stopper with some black silicone sealer. When it finally dries, I can reinstall the bumper and my problem should be solved.
Following is a picture of my button, which is similar to yours, only it's red.
(McMaster-Carr P/N 6915K242, 12 mm Harsh Environment Push-Button Switch Red Round Button With 19.7" Length Wire Leads) It cost $9.20 plus $4.00 shipping.
Old May 21, 2005 | 08:20 AM
  #45
SoFlaBoss's Avatar
Post
Originally posted by SoFL05GT@May 19, 2005, 9:17 PM
Hey Dustin,
Filling in the hollow rubber stopper/bumper thingy with silicone cured the problem 100%
Old May 28, 2005 | 04:13 AM
  #46
Snets's Avatar
Dustin, great write-up. BTW, for those of you who are not familiar with McMaster-Carr, they are awesome. Check their online catalog, if they don't have it, you don't need it.
Old May 31, 2005 | 09:52 AM
  #47
dustindu4's Avatar
Originally posted by SoFL05GT@May 19, 2005, 10:17 PM
Hey Dustin,
Sweet!!!
I'll have to try the silicone trick, thanks. I was going to order the same switch you used but I already had the other one lying around. I'm glad you like it.
Old Sep 30, 2005 | 02:36 PM
  #48
ualpow's Avatar
FYI a white/purple wire can be found in the passenger kick panel or SJB, blk 52 pin plug, pin 13. This wire just needs a ground to activate the trunk release. Would be easier than supplying power the the solenoid wire. (This information comes without warranty. Please verify all wiring questions with a knowledgeable tech.)
Old Oct 3, 2005 | 07:38 PM
  #49
dustindu4's Avatar
That should be helpful, for people that haven't done this yet.
If you can find this wire, attach it to one lead on a switch and the other lead tie to a ground (attach to a metal piece somewhere).
Old Oct 7, 2005 | 12:05 PM
  #50
364's Avatar
364
Originally posted by Montrose@May 1, 2005, 5:51 PM
Right where the monkey can reach it.
Do you have a trunk monkey in your stang? I ordered mine last spring and have been on the waiting ever since.
Old Oct 7, 2005 | 11:36 PM
  #51
ualpow's Avatar
Ordered my monkey on 8-10-06 and it is still clean and unscheduled..........
Old Oct 8, 2005 | 10:56 AM
  #52
htwag's Avatar
We need to develop a site-related "how to..." section with more detail.
Old Oct 9, 2005 | 07:28 AM
  #53
DanteMO's Avatar
I totally agree. It would be great to have a how-to forum. Only thing allowed in their are writeups for DIY...
Old Oct 9, 2005 | 10:25 PM
  #54
panamajk89's Avatar
I'm picking my switch up from McMaster-Carr tomorrow morning. I'm tired of having to bring my keys with me every time I need to get in the trunk. It's a complete pain in the hiney. Thanks for your write-up, Dustin!
Old Oct 10, 2005 | 10:14 AM
  #55
dustindu4's Avatar
no problem
Try to mount the button as close to the rubber bumper as you can, and fill the hollow bumper with silicone sealant. This will help prevent the button being pushed if someone hits it with their knee.
Old Nov 9, 2005 | 11:26 AM
  #56
panamajk89's Avatar
Okay, this has driven me nuts the past few weeks. :angry:
I got everything wired in according to your directions, Dustin, pressed the button...nothing! I check the voltage on both leads and see nothing. When I press the installed momentary switch, my ohmmeter indicates the circuit closes. Conversely, when I press the trunk release button on the fob, the pink/orange wire is hot, 12V. That being said, if I tap the pink/orange wire and attach the other wire to the negative lead on the battery, how is voltage getting provided to the trunk release when I press the button? What am I missing here? :scratch:
Old Nov 9, 2005 | 07:23 PM
  #57
ualpow's Avatar
If you are using the Pink/orange wire, you have to supply posiitive voltage through the switch. -OR- You can supply a ground through the switch to the white/purple wire in the passenger kick panel or SJB, blk 52 pin plug, pin 13 to open the trunk.
Old Nov 10, 2005 | 11:04 AM
  #58
dustindu4's Avatar
You need to give the pink/orange wire some juice, which I described doing in post #20
Buy a mini fuse add-a-line at the car parts store. You can see in the picture which fuse I pluged into. I used a 3 amp fuse for the button. Crimp the add-a-line to the other wire for your button and plug it into the fuse box. I already had a slot cut, but you will need to dremel a slot for your wire to stick out of the fuse box cover.
I'd first try doing what ualpow said and try to find the white/purple wire he is talking about. Strip some insulation off it if you find it and arc it to the body and see if it releases the trunk. That's a better way of doing it I think. When I did it I didn't know you can do that.
Old Nov 12, 2005 | 12:05 PM
  #59
panamajk89's Avatar
I'll give it a try again soon, Dustin. I've been busy the past several days and just haven't had the time. I'll keep you posted.
Old Nov 14, 2005 | 10:48 AM
  #60
dustindu4's Avatar
you'll get it, it will work
