How to get around the parking brake thing to watch dvd's
Old Aug 17, 2006 | 09:30 AM
Dirty Sanchez's Avatar
I just installed an alpine iva-w200 (double din dvd player and screen), and id like to know how to bypass the parking brake. Ive heard a toggle switch can be used, but can someone tell me how to do this? Thanks
(no i am not dumb enough to watch a dvd while i am driving, but i would like my passanger to be able to on road trips)
Old Aug 17, 2006 | 10:15 AM
pittperson's Avatar
I'm no wiring expert but I'd think you could tap into the wire that runs to the parking break. Run a wire to your toggle switch and one from the switch to the fuse box, turn the switch on to draw power to the parking break wire and your car would think it's on? I could be completely wrong but it makes sense to me!
Old Aug 17, 2006 | 10:27 AM
that is what im thinking to. Was wondering if someone has done this before, dont want to screw up a $900 deck
Old Aug 17, 2006 | 10:52 AM
OKCMustangGT's Avatar
I am almost positive that Adrenaline did that. What about the bypass kits I see on eBay? Good or just BS ?
Old Aug 17, 2006 | 03:27 PM
Treadhead's Avatar
I don't know where you are but, some states have laws prohibiting video monitors being on when they are viewable from the driver seat with the car in motion(this does not include navigation screens). Just something for you to consider in case you weren't aware of it.
Old Aug 17, 2006 | 03:30 PM
Exactly why a "toggle" switch is required.
Old Aug 17, 2006 | 03:32 PM
HastaLaVista's Avatar
Seems overly complicated. Find the switch that's pushed when the parking brake is pulled. Wire another switch (hidden in the arm console) to the same wires. When either one is closed system will think brake is activated.
No need to run anything back to the fuse box.
Old Aug 17, 2006 | 03:39 PM
i have illegal tint, no front plate (illegal here), no cats, clear corner lenses with white bulbs (waiting on stealthbulbs to send mine), and several other off road mods. Im not to worried about it being illegal but thanks
Im guessing both wires recieve a power as it says to splice into the brake lights, but according to my manual. i have ot have the key in acc position, press the brake down, pull the e-brake. release the e-brake and pull on it again, THEN the monitor willl turn on. Im thinking if i just hook up the brake wire, then run the other to a 12v power sourced toggle switch. Press the brake down, turn the toggle switch on, then off, then back on, this shoudl do it. Now, if only i still had my owners manual, maybe i could find the wire to splice into the brake light wire..... anyone nice enough to look it up for me? can i find an owners manual online?
Old Aug 17, 2006 | 03:42 PM
Do a search on Adrenaline, he has a blog on his mods and adding the IVA-W200 is one of them. If I am not mistaken he has bypassed this problem, but can't remember how. I think he posted how he did it, I can't remember.
Old Aug 17, 2006 | 03:44 PM
Treadhead's Avatar
Yes, the ol' "Officer you must be mistaken." Good luck!
Old Aug 17, 2006 | 07:26 PM
Infinity's Avatar
Most of those units, all you have to do is ground that parking brake wire. IDK about the IVA specifically, but that's all I've had to do on all the others I've installed, including the Kenwood in the wife's Jetta, and a Clarion in a good buddy's Exploder.
Old Aug 17, 2006 | 07:36 PM
Lennyb44's Avatar
Number Cruncher
I must be gettin' old.
I've never understood the point of watching a movie while on the road.
(Even for passengers)
There's a whole dang world passing by outside the car.
That's how you learn about things (by observing them)
Rant finished. Back to your normal programming.
Old Aug 17, 2006 | 10:29 PM
FireFighterHill's Avatar
I have the pionner AVIC-N2 I believe it uses the GPS to tell if your moving. Id love to be able to have my passenger be able to do more with the GPS while moving. Ive been told the grounding of the parking brake wire wont work with mine.
Old Aug 18, 2006 | 05:54 AM
Infinity's Avatar
It won't. I think there is a software hack. Search for it.
Old Aug 18, 2006 | 01:45 PM
thanks Infinity, i will try that when i get my car tomorrow. You sure it wont hurt anything?
Old Aug 18, 2006 | 02:37 PM
You don't want to just ground the wire, you want a switch in there.
Grounding it will give you that "Parking Break Engaged" message in the dash. Not certain if that state affects anything else, don't know how the computer reacts to that being on.
Old Aug 18, 2006 | 07:04 PM
Hey Infinity I looked up the hack it says I have to solder a connection and ground the parking brake, but then I read by others that it doesnt work and will fry my system!
Old Aug 18, 2006 | 08:39 PM
Infinity's Avatar
No, DO NOT ground your parking brake. Ground the wire that goes from your head unit to the parking brake.
FFH, I'll look to see if I can find that hack. I know I read it somewhere. It involved flashing the firmware.
Old Aug 18, 2006 | 08:45 PM
Infinity's Avatar
There's apparently a way to run in/outs with an RCA line using the rear-camera feature. But, I'm not sure
Old Aug 18, 2006 | 08:57 PM
Hey that was a typo I ment to say ground the wire that goes to the parking brake.
