How do you remove back seat?
Old Dec 2, 2005 | 01:34 PM
cyoon's Avatar
Is there a pdf on how to remove the back seat? I guess it must be simple, but I just wanted to know if there are instructions. I'm just wanting to remove the bottom part of the seat.
Old Dec 2, 2005 | 02:32 PM
lodom's Avatar
On the bottom of each side of the rear seat cushion there is an attachment point to the floor of the car. You may have to lift up the the cushion some to look under it. Once you've located the bracket, take a standard screw driver and push towards the rear of the car in the center where it attaches to the floor of the car while lifting up the cushion. The cushion should pull right up. Don't pry on the connector, just push towards the rear of the car. The button in the center is spring loaded.
Old Dec 2, 2005 | 10:53 PM
pony power's Avatar
thanks for that I too need to remove the lower cushion
Old Dec 5, 2005 | 02:18 AM
vc4life's Avatar
why are you guys removing the lower part of the back seat??
Old Dec 5, 2005 | 06:58 AM
Zodiac's Avatar
Rear seat delete... little weight removal for the track.. subs?
Old Dec 5, 2005 | 08:32 AM
NOLAGT's Avatar
How do you remove the rest of the back seat? I will be putting in a sound system
Old Dec 5, 2005 | 06:29 PM
vc4life's Avatar
i just got done doing 4 12's in the back seat but we took out the top and bottom to build the box
Old Dec 6, 2005 | 11:20 AM
cyoon's Avatar
I'm doing it so I can run my Sirius Satellite Antenna under it through the center console to the back.
Buffet Slayer
05-09 Interior and Audio Mods
37
Feb 18, 2016 12:58 AM
HizliBullet
GT350
14
Nov 14, 2015 08:59 AM
MRGTX
Aug 30, 2015 12:14 AM
Earlsays
Aug 5, 2015 07:10 AM
