How do I get this off?
This is on te drivers side of an 05. Im trying to run speaker wires through th door into the cabin. But this seems to be blocking the wires exit. I think its the stock amp. Ive removed a few bolts from it and the plate itts resting on and still cant get it off. Any help/suggestions?
UGH talk about a pain in the ***! I never removed my stock amps for that reason; I was able to get my speaker wire (from door speaker and new door sub) to snake through the boot (inside the boot, but above the wire connector) in the door jamb and down behind the plate on which the amp is mounted. I dont remember how i snaked the wire down, because it looks pretty tight back there, but I probably taped the wire to something, like a small ruler or a hanger or a paper clip thats been bent straight
ok lol yea i fugured there wasnt goign to be an easy way to do this. I think Ill give the taling to a wire a try. I cna even see where they are suppsoed to come out..should be interesting.
Yea I finally for it off! You were right about the pry bar, It took some convinving to pop it off. The plastic spacers seemed to have some kind of grove system to keep it from coming out. with that I dont know why they even bother putting nuts on it.
I kind of had a feeling about that when I looked at mine. I guess the plastic could eventually wear down and then you don't want an amp hangin by the wires.
The passanger side was so much easier, however I put everything back together and now nothing on the passanger side works(window, speakers, locks ect.). So I'm assuming the door harness didnt plug back in all the way. I'm going to check it when I get home from work. I hope thats all it is lol
