Help with antenna on shaker 500
Last night I put a start button in my car. While I was at it I also put a PIE adapter in. Everything went well, except my radio gets no reception. CD's work and the radio works, it just won't pick anything up. I'm sure I pulled the antenna wire off.
Where is the connection on the back of the radio? Is it a normal antenna plug like I have always seen, or is it one of Fords better ideas?
Follow it back to where it is strapped to the bracing and unhook it to give you that needed extra inch or two to get your hands in there. I have a boatload of cables/wires run to that area, and I need all the space it can afford.
Steve@CJPP
9/15/15 06:20 AM
