Help with antenna on shaker 500
Old Jul 13, 2006 | 05:54 AM
mustangjack's Avatar
Last night I put a start button in my car. While I was at it I also put a PIE adapter in. Everything went well, except my radio gets no reception. CD's work and the radio works, it just won't pick anything up. I'm sure I pulled the antenna wire off.
Where is the connection on the back of the radio? Is it a normal antenna plug like I have always seen, or is it one of Fords better ideas?
Old Jul 13, 2006 | 10:44 AM
dustindu4's Avatar
9 is not my lucky number.
IT's the fat orange wire with the big banana plug on it
Old Jul 13, 2006 | 12:55 PM
CHDS PNY's Avatar
that plug is very touchy
if you think you have it in...double check and make sure it is in...otherwise it will pop out
Old Jul 13, 2006 | 03:50 PM
Infinity's Avatar
Follow it back to where it is strapped to the bracing and unhook it to give you that needed extra inch or two to get your hands in there. I have a boatload of cables/wires run to that area, and I need all the space it can afford.
duppycat
Feb 16, 2019 08:36 AM
Steve@CJPP
Sep 15, 2015 06:20 AM
scott6809
Sep 12, 2015 11:44 PM
