Chrome Shift Knob
Old May 31, 2005 | 11:49 AM
Xader Vartec's Avatar
Can anyone point me to a chrome or aluminum finish shift **** for the 2005 mustang?
Old May 31, 2005 | 12:05 PM
Or...a better question....is the thread on it 12mm?
Old May 31, 2005 | 12:12 PM
brown412's Avatar
No, I believe its 1/2" x 20. I've been looking for the same thing. Some people have re-tapped the threads and made that work.
Old May 31, 2005 | 02:56 PM
besides the boot tricks (which I've read about here) have you found any info on what will fit it stock?
I hear that universals don't fit very well. . .
Old May 31, 2005 | 03:21 PM
Ok...I have seen several places that mention that the new 05 has a different thread than the old shifters...however on ebay I see a couple of shifters that say they will fit all models from '94-05 (http://stores.ebay.com/DIVERSIFIED-MARKETING).
Is it really different?
Does anyone really care? (besides me)
Old May 31, 2005 | 08:37 PM
subzero05's Avatar
steeda has a polished version that I have on my car and they sent me an extra one by mistake I guess so if you are interested in it let me know =)
Old Jun 1, 2005 | 07:45 PM
wjones14's Avatar
the '05 thread pattern is not the same as '83 to '04. the '05 pattern is 1/2 x 20. The old pattern was metric.
But the ones on ebay may be universal *****, i.e. they may have interchangeable thread bushings. Beware of universal *****, however! I tried one once, and it felt cheap because there was a slight bit of play between the bushing threads, making the **** kind of rattle. Definitely not solid feeling.
Old Jun 1, 2005 | 10:31 PM
wild stray's Avatar
The only thing that's remotely difficult in resizing an older shift **** is securing the **** for drilling without damaging the chrome on it. I used an old mouse pad to wrap the ball and then used pine (soft wood) between the steel vise jaws and the pad. That worked OK, but you could prolly come up with a better idea. The drill size is 29/64". Measure the existing hole and put a piece of tape on the drill bit so you don't go too deep into the ball. After you drill the hole out, just insert a 1/2" x 20 tap.
Old Jun 2, 2005 | 08:04 AM
Thanks. This is the exact kind of information I was looking for.
Old Jun 2, 2005 | 05:30 PM
wild stray's Avatar
You're welcome, good luck. BTW I am having a Triax shifter installed and they use the old 12 mm? shaft size. For the new installation I ordered a '04 Mach I shifter ball which comes with the boot sleeve, (ordered from 05StangKC), they are aluminum and have the shift pattern ingraved on the head.
Either the chrome or the aluminum look good in the '05 interior.
Paul
Old Jun 2, 2005 | 07:44 PM
That is the EXACT shift **** I was looking at getting. I emailed an online shop about whether the threads were the same and they said no. After that I guessed that I couldn't use it.
But I showed your instructions to my father-in-law (he's a farmer with alot of shop equipment for working on tractors) he said we could do your retrofit in his shop so I think that will be the one I get now.
Thanks again.
Old Jun 2, 2005 | 08:08 PM
wild stray's Avatar
Here's a quick pic of the Mach ****.
Old Jun 3, 2005 | 01:44 PM
When you say "just insert a 1/2" x 20 tap" are you saying to tap the **** itself or put an insert into the **** that has those dimensions?
If you mean the later where would I get something like that?
Old Jun 3, 2005 | 03:55 PM
wild stray's Avatar
I just tapped the **** itself. You will have to make a decision based on the **** you buy. You will prolly be OK tapping the **** out as long as you drill it out straight.
Paul
Old Jun 5, 2005 | 12:24 PM
DozerzPony's Avatar
i like it
Gigantor
May 11, 2023 07:31 PM
K.A.I.N
Sep 25, 2015 03:27 PM
SterlingStunner
Sep 16, 2015 12:30 PM
earl610
Sep 6, 2015 05:48 PM
